It was working perfectly well, until I put a cushion to wash and it dissolved the sponge, I guess it was too heavy for the machine or maybe it was just a coincidence.
SOURCE: Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
SOURCE: burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
SOURCE: Horrible smell coming from the washing machine
Do a wash with just bicarbonate soda then wipe it out, including any rubber seals
SOURCE: My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
