Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a 2002 GE side by side the freezer works fine but the refrig side is not keeping cool enough.....Any help please.
  • 534 Answers
Your condensing fan in the unit may be out. This fan supplies the cold air from the freezer to the fridge. To find it look at where the temp control switch is in the fridge. There should be some vents in this area. The fan is located behind that panel. Once you remove the panel take the model number and serial number to the parts house and they should be able to get your fan part. If by chance the fan is rotating then it is possible your defroster is out. You will be able to tell if the defroster is out there will be a large chunk of ice in the area of the fan
Posted on Jul 15, 2009
GE Model TBX18JISERWH This refrigerator is a freezer on top/refr on bottom.....the problem is that the freezer section is working fine,but the refrig isn't cooling enough. The temo gets up to 48/49...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice or is cold . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 29, 2010 | Refrigerators
Refrig. Won't keep food cold but the freezer works fine. Milk spoils after 3 days in the refrigerator. What's wrong? The thermastat was supposely changed?
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
May 07, 2010 | Refrigerators
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
GE side by side freezer/refrig-model # pssz6mcpa-motor in freezer not running, icemaker not working and freezer not cold enough
Sometimes they stick and need a shot of WD 40 and then workit back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 04, 2010 | Freezers
Freezer stays cold but refrig does not
Hi, Look and see if there is frost built up in the freezer on the back wall.
If there is frost, it will not let air circulate properly and it means there is a problem in you self defrosting cycle.
Please let me know if this is what you find so that I can assist you further.
Thanks
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite Side by Side refrigerator not cooling enough
it could be either gas problem or may be compressor is not working
May 14, 2009 | GE GSS20IEP Side by Side Refrigerator
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
171 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
