Question about Samsung HLR5067WX 50" Rear Projection HDTV
No picture I recently had a problem with my HLR 5067W. It turns out it was the ballast (thanks localwonder for the help). But now the problem is back. The last time it happend right after a power outage and this time samething. I have the TV on a surge protector but i guess thats not helping. Any suggestions to keep me from haveing to buy a new ballast everytime my power goes out?
  • 304 Answers
Two causes at this point. First, Have you replaced the Lamp?. If not, how long has it been since the last replacement if it is not the original lamp? Second. Do you hear a Whining sound coming from the rear of the set. If so ,Replace the Color Wheel.
Posted on Jul 16, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
HLR 5067W 6yrs old. I replaced the lamp and color wheel about 3 years ago. Last week the TV would not turn on. Fans run hard, no light from the lamp. Tries for 3 cycles, then shuts down and front...
Tv is on every day and watches 4 to 5 hours every day?Yes,3 years now the projection lamp require replacement again and the board that call the Ballast board might require replacement too,this Ballast board only job is it to ignite the projection lamp only..
Jun 04, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
My hlr 5078 wont turn on it gives me 3 blinking lights
CK the Lamp Fan if it stops running Lamp will shut off, and Ballast board is what turns Lamp ON
If Fan is OK Look at Ballast board it connects to Lamp Plugins. Encompass Parts Distrubtion List Parts/Prices for this TV 1-800-638-3328
Let me know if you need any more help.
Mar 21, 2010 | Samsung HL-R5078W 50" HDTV
After changing color wheel on my samsung hlr 5067w tv my picture is high with black bar on bottom.top of heads are cut off.what went wrong? no proble before.
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works:
http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Feb 09, 2010 | Samsung HLR5064W DLP Projection TV
My samsung 5067w dlp tv does not turn on, the timer, lamp and temp/standby lights keep blinking. Please help!! Thanks
First check the color to see if its spinning or not. Replace it if neccessary. If that's ok, replace lamp and ballast.
Dec 23, 2009 | Samsung DLP HL-P5663W 56" TV
When i turn it on it turnes off after a minute
Check the color wheel. If that is ok, replace lamp and ballast.
Dec 14, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung hlr 5067
Replace Ballast Board Call Encompass 1-800-638-3328 or Look on E-Bay they have some good deals on New and used but works #BP96-00690A I checked they have them in stock for 64.40 Visit there website Encompass Parts Distirb.
Sep 28, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Dark pic on Samsung HLR5677WX/XAA
I have a samsung hls4676sx/xaa its has hundreds of white dots some are blinking how do I fix it
Jan 09, 2008 | Samsung DLP HL-P5663W 56" TV
Sound but no picture
there are several things that need to take place for the lamp to turn on. first the color wheel needs to turn on ( if you can hear a whinning noise then this is fine) next the tv will send a signal to the lamp ballast to turn on, and the ballast needs the 130v dc supply from the power board ( simoly remove the lamp and reinstall the lamp door, turn tv on, and if you hear an arcing noise from the ballast you know this is fine too. the board that controls all of this is the dmd board. so if the color wheel works, ballast starts then i would replace the dmd board....
Oct 24, 2007 | Samsung HLP5085W 50" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
208 people viewed this question
Jerry Greenberg
Jerry Greenberg
