Question about Ingersoll Air Tools & Compressors
I HAVE A MODEL 15T AND NEED TO KNOW WHAT TYPE OF OIL AND CAP.
    President:
  • 2,976 Answers
Contact an Ingersoll Rand service center. They will have the correct oil. It is quite expensive but, if you use the wrong oil, that's a lot more expensive. The cap is most likely just a pipe pplug, capable of withstanding the pressure.
Posted on Jul 15, 2009
Oil filter
look on front top right corner cylinder block. the 1.4 engine has the canister type oil filter.you need large socket and wrench to remove canister cap be sure replace the o ring in the oil filter cap housing.
May 29, 2013 | Cars & Trucks
I need a 15t counter sprocket for a 2007 Qlink Legend 250
If you are using an o-ring chain the 15t front sprocket will not work, you need to use a 520 x-link chain. Also get a 32t or 31t rear, 32t if you are riding in a hilly area, 31t for open road. JTF270-15 front and JTR279-31 on the rear.
May 18, 2013 | 2007 Qlink Legend 250
My Poulan Woodshark 14" type 2 (-2 on serial
Fuelleaking from the cap will not stop it running, 40-1 with good quaility two stroke oil shoule be fine, if there is a good spark and fuel at the plug, you need to check that the piston has not picked up, the hottest part of the engine is the exhaust side, so remove the muffler, and take a look at the piston skirt throught the open exhaust port, any signs of scuffing and it will need to come apart to check the damage.
Oct 11, 2011 | Garden
Which Engine Oil should I use for my Honda Civic, VTI Model 2000?
maybe the dipstick has the correct type of oil written on the side or top of oil fill cap.if not a parts store should know the coorect type. my guess would be 5w30, 10w 30 ..just a guess but that should give you an idea
Feb 14, 2011 | 2000 Honda Accord
The clear "bubble" inside my oil cap that you depress is missing
Without a model number I cannot be of more help.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
An oil cap is part number “107512-01” (please verify this fits your saw).
Remington.com
· Type "107512-01" into the “Search for your parts by Part #:” window, then click search.
A couple of clicks later is says; Part #: 107512-01; Price: $4.72; Description: OIL CAP WITH BULB.
MasterParts.net
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=SRCH&Store_Code=MPD
Type “107512-01” in the Search For The Following Word(s): window. It returns 107512-03; $8.45 (3 each 107512-01s).
RemingtonPower is no longer in production. Eventually eBay will be the primary source of replace parts.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Remington Electric Pole Saw
Where could I order a cap for the chain oil for a
Your oil cap is part number “107512-01”.
Remington.com
MasterParts.net
Lou
Apr 02, 2010 | Remington Polesaw Wizard
What type of bar oil do I put into a Remington electric chainsaw? (no manual, model #107624-01 ,16"bar
From page 9 of your manual:
FILLING OIL TANK
  1. Remove oil cap.
  2. Fill oil tank with SAE #30 motor oil. Note: For temperatures below 30°F, use SAE #10 oil. For temperatures above 75°F, use SAE #40 oil.
  3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
  4. Wipe off excess oil.
Note: It is normal for oil to seep when saw is not in
use. Empty oil tank after each use to prevent seepage.
Like so much of what MrFixIt posts his opinion is based on BS. He can never take the time needed to provide any answer that actually requires thought or research!!!
Use bar oil available at any home center or hardware.
You can download your manual here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH
Lou
If you did not rate his answer please give it the NOT HELPFUL rating it deserves.
Dec 31, 2009 | Remington 16" Electric Chain Saw
Air Tools & Compressors Logo
105 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
