Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
I have a dishwasher with the clean light blinking and i have replaced the thermistor it worked fine for about 1 load but then came back on
  • 1 more comment
  • sienemesis Jul 15, 2009
    i have also checked the heater element its good, when i ran it threw a cycle after i replaced the thermistor i had it on heated wash and it was a very heated wash, is it possible that there is something else wrong here?could it be the control panel? everything has tested good. should i try to clean out the pump, and im not sure how many times the clean light blinks, i just know that it does, could it blink for another reason?
    i have a dishwasher flashing clean how many times i dont know, i changed the thermistor and it worked for one cycle, didnt finish the next cycle, the heated wash worked fine, the heater is fine i checked it, what else could cause the clean light to flash?
    its whirlpool m# gu2500xtpb6
  • 2,200 Answers
First check that the thermostat has not tripped. If you have recently changed the thermostat you alreadt know where it is located. Underneath or near the thermostat there is a red button. With the machine off and unplugged - reach in and press this button. If you hear a click the thermostat has indeed tripped and is now reset.
Try the machine and report back. Please identify at what point in the cycle the machine is stopping e.g rinse,drain etc to further help in troubleshooting the issue.
Posted on Jul 15, 2009
  • Radio Code Pro
    Radio Code Pro Jul 15, 2009
    Additionally - is this a Kenmore machine? Please provide exact make and model no.
    Thanks.
  • Radio Code Pro
    There are reports of control panel failure causing this on this machine - however before we go there - there is a button combination which can be used to reset the machine and this is worth a try.
    The most common combination is at 1) although there is a variation between models.
    1) Push the Normal Wash then Heated Dry buttons in that sequence and repeat for two to three times. The unit should enter diagnostics mode. This can be stopped by pressing the Cancel button. This will clear any existing faults. Shut door and run cycle.
    If this fails these buttons may apply
    2) With door open - press Sani Rinse, Air Dry, Sani Rinse, Air Dry and repeat a couple of times. Repeat until all lights up. Shut door and run cycle.
    4) You may find these buttons apply to your machine - repeat as above. Hi temp - air dry Hi temp -air dry.
    Try this and report back. Also confirm thermostat has been reset as per previous instructions.
    Thanks.
  • 3,037 Answers
Is it blinking seven times, continually, or a different number of times?
A clean indicator that flashes/blinks 7 times and then repeats, indicates a problem in the dishwasher which should be investigated and not just the control 'reset'! That is why the control will not let the dishwasher start once such a condition is detected.
If the dishwasher's electronic control doesn't detect a water temperature increase during the main wash cycle, that symptom can occur. No water temperature increase could be caused by a problem in the heater element, its in-line thermostat which you already replaced, the related wiring or a problem in the electronic control.
It is also possible just the washer not spraying properly (possibly from blockage in the filter or problem in the pump), the dishwasher not filling sufficiently or draining prematurely or even a problem in the door latching mechanism's switch(es) could cause it.
Once corrected, the error display may have to be cleared from the control manually (Did you do this?). That can usually be done by putting the unit into diagnostic mode by pressing the key sequence 'Heated Dry, Normal, Heated Dry, Normal' and then pressing cancel.
Benjamin
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Clean light blinking
Does the light blink 7 times pause then repeat if so then there a problem with the heat circuit could be a bad heating element a wire off the element a bad thermistor or a control not outputing voltage to the element.
Feb 06, 2014 | Amana ADB1600AWS Builtin Dishwasher
Clean light blinks seven times and will not start on any cycle.
The problem you are having is that the dishwasher is sensing that the water is not getting hot enough to finsh out the cycle. The first thing you need to do is get the dishwasher into diagnostic test mode, you can do this by pressing: normal wash then heated dry, 4 times. After in diagnostic mode you can exit out by pressing cancel/drain. This will get rid of the blinking clean light and the washer can be operated in any cycle now. To prevent this light from coming back on, you can do one of two things. First you can just try running Hot water at the faucet before each time you use the dishwasher. Or, you can replace the thermistor/sensor that senses the water temperature. You can purchase this part at this link http://www.repairclinic.com/Sensor-Or-Thermistor-Parts?s=t-DU1055XTS-%3d%3dc61
Nov 27, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
There are 3 blinking lights on the control panel of my Fridgidaire PLD2850RDS3 dishwasher that will not turn off. The dishwasher will not run
I found where it was plugged in under the sink. I unplugged it and the lights stopped blinking and the dishwasher worked. I ran one dishload and it ran fine. I ran another one and it stopped at 1 minute to go and the lights were blinking again. So now I just unplug it when not in use. I'm runnin another load and see how it goes...
Feb 09, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My whirlpool dishwasher is flashing 8 times - I pressed and held the start button to reset and then pressed start again, it kicked in and started to fill with water and stopped again - any ideas.
Hello, I have a Whirlpool DWF A10. The machine starts then stops after a short while and the indecator light flashes 7 times. What does this mean? Any body come across this?
Jan 11, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Does not go thru dry cycle, clean light blinks 7 times
Remove the front door panel and look for a broken wire.  Usually the broken wire is about 1/3 of the way up from the bottom of the door.  The wire tends to get stuck into the insulation causing the break.  Repair the wire connection and then cover the affected wire harness with a plastic cover to separate the harness from the black insulation.  If there is no broken wire, then the thermistor needs to be replaced.  That will require the entire unit removed to access from the bottom of the dishwasher.  Thermistor failures are very, very rare.
Jun 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
May 09, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
clean light blinking is a tricky problem to find and cure can be a few different issues.heres an edited down version of official manufacture explaination,its been an issue (I would call manu for assisstance in repairing this further)
A heater fault detection program has been added to the electronic control to check for temperature rise and shut down dish washer. If the temperature rise is less than the criteria, then the unit will drain and blink the clean light 7 times. The Proper incoming water temperature should be between 120°- 140° F.
Possible causes of insufficient temperature rise would include wires off at thecontrol, heating element, thermistor,inlet valve, door switch, motor or capacitor, failure of any of the above components or siphoning of the water during fill.
Feb 27, 2008 | Kenmore 24 in. 16034 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
113 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
