Question about Motorola Mobility H700 Wireless Headset
I have no idea how to work my headset
All it dose is turn blue and then go off and i cant hear any thing
  • vpsingh Nov 24, 2007
    i've sanyo m1 phone with sprint. I charged motorola H700 device until it turned green, then i removed it from the charger.Now i turned on bluetooth of my phone and changed to handsfree setting then paired my headset with sano M1 phone but I couldnot receive any phone calls.So I delected the device from my phone and try to reconnect to motorola headset.Now it doesnot show anything in my phone. Is there anything to reset the headset, because now the headset is showing flashing blue light evenif i dont see it in my phone.
    any one,please
    thanks
One additional step to get the H700 to pair again -- After you close the boom and hold the call button, when the light turns purple, open the boom. This puts the H700 into pairing mode.
Posted on Jun 27, 2008
I was having the same problem with my phone. First close the boom on your headset and hold the call button until the light turns purple. This will reset the headset and prepare it to pair up again. Once that is complete try pairing it back with your phone. If it still does not work, you might have to manually connect to the bluetooth headset from there. Go into your trusted devices on your phone. Select the bluetooth device, select connect. Hopefully that works. If not try calling 1-877-motoblu and ask for customer service and see if they can walk you through any other solutions.
Posted on Jan 09, 2008
Ps3 afterglow headset is not working??
mine headset is blinking and it don't work or turn on. please help me
Nov 26, 2011 | Radio Communications
I am trying to hear my gameplay through my plantronics gamecom p90 headset i got the headset to work but i cant hear my gameplay through it
If your headset is the P90, turn the headset on. The light on the headset should start flashing red/blue. If it doesn't, start with the headset turned on, press and hold the call control button on the headset until the light on the headset starts flashing red/blue, red/blue. Follow the on screen instructions and let the PS3 scan for the headset. It will appear as "P90Plantronics" in the list of devices. If prompted for a passkey, enter 0000 (4 zeroes). Now go back to the Accessory Settings menu and then select Audio Device Settings. Select "P90Plantronics" as the audio input and the audio output device. You should be all set. If not, you can contact the Technical Assistance Group at 800-544-4660 x5538.
Good luck from Headsets Direct - 800-914-7996.
Aug 10, 2011 | Plantronics GameCom X10 Headset
Cant hear on my blue parrot headset. it was working fine then just stopped. its showing that my phone and headset is connected.
try this: have both on but not in use,plug the charger in for 10 secs only then unplug, watch lites go from red to blue then flashing just blue at a rate of 1x per second. that resets it. worked for me.i called the company
May 17, 2010 | VXI Corporation Blueparrott B250-XT...
Hello, ok my headset shows up on my television and is fully charged but i cant talk or hear from it? can u help me?
you need to go to audio device setings and switch the input and output devices to 8860 hen push your triangle button and selec the connect option but make sure your blue tooth is flashing red and blue first. i hope this helps cause i just went through the same thing and this is what i had to do!!!
Jan 09, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Mic is synced but cant use online
my problem is the mic wont syncronize and wont respond to my voice and i cant hear other people through it .it still flashes blue and charges fine
Aug 30, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Cant hear anything
ya im having the same problem with mine, and im trying to play cod6. but i think its supposed to do that. but then again, why would they give u a earpeice if u cant hear anything. well, u can try pressing the volume up on the head set, and also go to accessory settings on your ps3 and turn it up. but im not sure if thats your problem, i havent tryed that yet. but hope it helps.
May 26, 2009 | Mad Catz Radio Communications
Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Mar 04, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Blue light will not stay lit
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 30, 2008 | Motorola Mobility H700 Wireless Headset
Blue tooth adapter and hs850 headset on my computer
Yes, you need the blue tooth driver. The one that comes with your blue tooth "toggle". Although my laptop said "blue tooth compatible" I still needed a toggle. They are fairly cheap to buy and go into a USB port.
Sep 17, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility H700 Wireless Headset Logo
214 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
