In copying envelopes I am finding ink spots. What should I do?
  • 203 Answers
Depends for which bran and which model do you talk about if is a ink-jet printer on the side has a lever which when is in up position is for printing on envelopes and when is in down position is for printing on normal paper . Also you might should do maintenance program execute please tell me for which brand and model is about for to help you more specific
Posted on Jul 15, 2009
Only when I print envelopes #10 do I get big, dark ink spots..... whats wrong, this is a great printed and no problems otherwise.
I agree with Brian Lee on his first point. When the envelope bends slightly as it goes through the rollers, it deforms and a part will be raised higher than normal. That part will brush the underside of the print heads and give you the black smudge. You will probably hear a slight swishing noise as the envelope prints. That is the sound of the heads brushing the paper.
The best solution for this is to print labels and stick them on, or to use windowed envelopes and print the information on the letter or form so that it shows through the window. Hope this helps.
Jun 28, 2015 | Canon PIXMA MP600 all-In-One InkJet...
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
Irregular ink spots all over the text
Are the ink spots in the same pattern down the page ? if so it sounds like a bad drum. try and make a copy using only one color at a time, to try and tell which drum it may be. If the spot are random down the page it may be the ITB belt cleaner.
Apr 17, 2010 | Canon imageRUNNER C3200 Copier
Ink spots and blurring on envelopes - no problems with regular paper on hp Deskjet 1280
For envelopes and other special paper types, you have to tell the printer what kind of paper you are using so that it can adjust its print settings. In the printer properties, set the paper type to envelope or thick paper and try printing again.
Feb 05, 2010 | HP DeskJet 1280 InkJet Printer
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
When I print enveloppes with my Konica 2430DL, I get shadows, but not on other print jobs
When you look at an envelope, it has spots where there are 2 to 4 thickness of paper in spots.( folds of the envelope) If this is where your shadows are, and your printer does not have any settings for envelopes, your printer may not be able to print those types of envelpes. You might try a lighter and thiner envelope.
Mar 03, 2009 | Konica Minolta magicolor 2430 DL Laser...
Can't Print Envelopes, No Ink being used
Set tray 1 for the correct size envelopes in printer properties.
Feb 21, 2009 | HP LaserJet P2015dn Printer
Spots on master
THE DRUM THAT MAKE THE COPIES IS DURTY OR HAS DRYED INK ON IT AND IT TAKES A SPECAL CLEANER, I CAN NOT EVEN SAY THE WORD OR EVEN SPELL IT FOR YOU
TRI ETHI LINE, CALL A COPY MACHINE COMPANY OF GO ON LINE TYPE IN MANIFACTURE NAME ONLY RETURN ,
THE CORRONA WIRES THAT MAKE THE ELECTRO STATIC IMAGING MAY ALSO NEED TO BE CLEANS, Q-TIP AND ALCOLHAL WITH A VERY SOFT HAND OR YOU WILL BRAKE THE WIRE AND THAN YOU WILL BE WITHOUT A COPIER
CANDYMANGANDY
Jan 29, 2009 | Riso RZ310 Duplicator
Print poor copy quality
Fuser pressure (2 green levers on fusing section) may be set to envelope position.
Mar 04, 2008 | Konica Minolta bizhub C250 All-In-One...
37 people viewed this question
k24674
jasbo
jasbo
