Question about AT&T Blackberry Curve 8300 Smartphone
It rolls but will not select - AT&T Blackberry Curve 8300 Smartphone
    Brigadier General:
  • 7,752 Answers
You may need to have the trackball cleaned or replaced so take it to a mobile repair shop and have it done.
Posted on Jan 31, 2010
A1 rotation from A0 roll
I could't understand the question exactly..I will try my level best, it may helps you..
T770 plotter having three media paths..
1. Sheet path
2. Roll 1
3. Roll 2..
After initializing, printer will ask to load the media, you have to specify the desired media selection ie sheet, Roll1, Roll2..
If U R selected roll one, message appears on screen "Open Roll 1 cover", you have to follow the message, once the paper is loaded in the path, printer has to detect the paper,it has to pull inside with the help of the roll feed motor..
In this case If UR selected Roll 1 on printer screen & inserted Roll 2 media, printer will runs Roll 1 motor, not roll 2 motor.. This problem U might be facing..
If my suggestion is not helping U, pl let me know exact problem what UR facing...
Apr 26, 2014 | HP DESIGNJET T770 Printer
Need drivers for this mouse
You can either 1) re-install the driver, or 2) roll back the driver. Either one of these may help. To roll back your driver in Windows XP, go to Start --> Settings --> Control Panel --> Mouse. Click on the "hardware" tab. Select the appropriate pointing device, and click "properties." Click the driver tab, then select "roll back driver."
Under the "hardware" tab, there may be more than one mouse. If this is the case, select the one that is not used, follow the settings above, and then select "uninstall." Or, you can go into Control Panel --> System --> Hardware --> Device Manager, and remove the device under "Mice and other pointing devices
Jan 18, 2014 | Kensington PilotMouse 72129 (DH72129)
Ther are save photo album i want to delete it but it cant
To delete synced photos and videos
  1. In iTunes, select the device icon in the Devices list on the left. Click the Photos tab in the resulting window.
  2. Choose "Sync photos from."
    • On a Mac, choose iPhoto or Aperture from the pop-up menu.
    • On a Windows PC, choose Photoshop Album or Photoshop Elements from the pop-up menu.
  3. Choose "Selected albums" and deselect the albums or collections you want to delete.
  4. Click Apply.
To delete Camera Roll photos and videos
There are two methods to delete items from the Camera Roll:
or
  • Delete photos and videos from your device manually. Open the Photos application, open the Camera Roll, tap the Action button, tap each photo to select it, and tap the Delete button.
Oct 15, 2013 | Apple iPod touch
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Error 45.1.03 for t770
switch off the machine, remove paper and spindle of both roll & 2, close the roll covers, switch on the machine wait until ready mode appears, select load media, select roll 1. Load spindle in in the bank, verify properly seated or not, insert paper to load wait to printer perform load media..if successfully loaded issue closed..:Other services are not advisable to users only professionals can resolve the issue..
Feb 01, 2012 | HP DESIGNJET T770 Printer
Hi, I have USB keyboard and I installed PS/2 optic mouse to my PC. Mouse doesn't work .i have windows 7 ultimad 32 bit and MB DH55TC intel i am changin my optic mouse by roll mouse and again dont...
click start control panel view devices and printers you should see your mouse right click mouse you could open it and then select configuremy mouse or select settings then hardware make sure you have the correct mouse selected also right click on the mouse select properties to make sure you have the correct mouse right click on mouse you can troubleshoot this will activate the troubleshooting for you
hope this will help
Jul 23, 2011 | Computers & Internet
Looking for a manual for a 3648 III roll up
Go to www.gtco.com, select Tech Support/Large format Digitizers,then select GTCO Brand on the bottom of the screen, then select documentation and a PDF file can be downloaded.
Dec 17, 2009 | GTCO Roll-Up III Digitizer Graphic Tablet
My computer no longer reconizes the cd burner model 38631
Have you tried to update or roll back the drivers? On your desktop select start, click control panel, double click system, select the hardware tab, click device manager, click the + sign next to DVD/CD-ROM drives, right click on your cd burner, click properties, select the drivers tab, try both Update driver and roll back driver.
Oct 11, 2009 | Computers & Internet
Can't select Velvet Fine Art media type when using sheet feeder as source.
I had the same problem, same printer. So with a little checking I found a solution. The paper has to be fed through the single page paper feeder. (See manual to setup. Can be downloaded from Epson.) Select manual/roll in the page setup section when you're ready to print. For instance, I was using 8.5 X 11 velvet, so select letter > then subset of roll/manual. After doing this velvet and other specialty paper profiles were selectable.
May 28, 2009 | Epson Stylus Photo R1900 InkJet Printer
Hhow to save a pattern in fl studio and reuse the same in another
Open up the piano roll window for the sample you have selected. Use the highlight tool, which looks of a dashed square, to select the entire pattern by dragging your cursor from the top right corner of the piano roll diagonally to the left bottom corner of the piano roll. If you can't see all of the bars used, then try sizing the track in the piano roll closer together by placing your cursor on the square directly to the right of the horizontol scroll bar. Hold down the left click and move your mouse down to track the piano roll closer or move the mouse upwards to span it more. Select all of the bars used in the piano roll and click the down arrow in the very upright corner. Select Edit > Copy. This will copy all of the bars in the current piano roll. To paste the pattern simply click the down arrow again in the upright corner and select Edit > Paste in any piano roll.
Jan 20, 2009 | Image Line FL Studio 5 Producer Edition
AT&T Blackberry Curve 8300 Smartphone Logo
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
