Question about Gateway FX7026 PC Desktop
Graphics card or motherboard problems...
My fx7026 ran fine for 14 months then other day on the post screens I got several zeros all over the screen. It would not boot beyond the boot screen with the windows progress bar zipping away. I did notice the the progress bar had some odd colors to it. I was able to boot into safe mode. Ran virus scan, check updates and other logs... nothing jumpped out at me. I pulled the graphics card and switched to the intergrated graphic. The zeros on the post screens went away. After about 30 minutes of "windows has detected new hardware", finally the computer booted normally... Well almost normally so far my quickest boot time in the last 2 days has been 8 minutes... I've noticed that my system tray icons seem to vary now... sometimes almost all items are there other times it looks like a ghost town with only a few there. every thing seems very random... I have had on some reboots had the integrated graphics not load properly which leaves me stuck on a 4:3 aspect ratio on a 16:10 monitor, then the next time it loads fine. The ntbtlog.txt has not recorded the last few reboots no matter what I do so I can't see if various drivers are conflicting on boot. I'm stuck between two theories right now... a) the graphics card went bad and now windows is having issues booting because the start up restore (on a few boots it has done the startup restore) still has the graphics card rather than the integrated graphics. b) it is actually a problem with the motherboard. Removing the graphics card got rid of the Zeros and allowed the computer to boot however since I am still having random issues within windows (i.e. my system tray) ... certian hardware may not be seen which is causing random drivers to load or not load causing the slow boot times. I'd hate to replace the graphics card only to find out that a new graphics card doesn't fix the issue. Any ideas.
    President:
  • 2,976 Answers
You've run the antivirus. Next, try to run malware & spyware programs. THen, run a good registry cleaner. This will aim the right things with the right things. If you made ANY changes to hardware, software, programs or data, there will be changes in your registry.
Posted on Jul 15, 2009
I have an Acer 5750, which is only 14 months old. I do a lot of graphics work, for the web on it, recently when looking at graphics that have been developed in, for example, fireworks I have noticed that...
Try changing the resolution of your screen this may fix your problem.
If you you can see the images your graphics card is fine.
increase your resolution and make sure that you are using true colour scheme for you graphics setting.
Nov 26, 2012 | Acer Aspire 5750 Laptop / Notebook
After working fine for about a month, screen suddenly froze with a few artifact lines. restarted computer with nothing on screen and continuous series of long beeps coming from case. This should mean a...
best thing to do is to get an RMA of your motherboard because even if you still want to use the a dedicated video card the side port video memory of your motherboard is still faulty..and for you to avoid other future problems with the motherboard
Sep 17, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
I have a d945 GCNL motherboard, Nvidia 7200GS is the PCI-E Graphics card. The Issue is this when i insert the graphics card into the PCI-E slot, the onboard monitor output stops working (Though i can use...
Unfortunately this is not possible on any operating system. Once the Graphics Card is plugged in it deactivates the other VGA Output. The only way you will be able to get two screens to work on your computer is if you buy a a graphics card that supports dual screen capability.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 06, 2010 | Computers & Internet
Hi i have a KT4V motherboard and recently got a radeon 9800 pro graphics card - and upgrade form a radeon 9250 (which worked fine on xp but when i upgraded to windows 7 it wasn't supported). when i first...
Yes and No. Let me explain. You have taken an older board that worked with XP and tried to make it work in Win7 (which is not supported by the board). Add in your graphics card switch, and you have a real mess.
You can upgrade your motherboard (for one that is compatible with Win7 - (ie. a brand new model with Win7 certification) and use a graphics card that is also Win7 compatible, or
Go back to a configuration that worked
Dec 16, 2009 | MSI KT4V (MS-6712) Motherboard
Motherboard or on-board graphics card failure
I had the same kind of stripes on my hp dv9000. I read in forum that it was a heat problem, that loosens the soldering on the GPU chip.. I wrapped it into a towel for approx 30-60 min.. That removed the stripes in bios screen..
Jul 10, 2009 | Acer Computers & Internet
Powers up, but screen just black, no display...
If something's broken, thre's some things it can be.
First, try replacing your monitor cable. If that doesn't help, try another monitor. If that's also not working, it will probably beyour graphics card that's broken.
To find out you will need to replace your graphics card with another one, and then try to boot the computer.
Maybe you can replace those parts yourself, or know someone who can. If you don't know what you're doing, then don't do it, and post back here and we'll work out anothr solution.
Anyway, once you've replaced the card boot up the PC. If it's running fine now, you know your graphics card was broken, and you can buy a new one.
If it still doesn't work, your motherboard is broken, and you'll need to buy a new motherboard for your PC.
I hope this fixes your problem,
Yannick.
May 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Gateway FX7026 w/ 8800GT 512MB Video Card / Vista 64 Premium OS
It is a known issue. It is not a fault with the card, but a power saving method used by Nvidia. If the card is not being stressed, or even if it is, it will clock down to it's 2d speeds. This is fine if you are just surfing the web or other light tasks, but can cause chaos if you are gaming or folding at home.
You can force your card to run at it's maximum clocks in 3d mode by using a program called Riva Tuner. There are several good posts on the net on how to use this fix, but I can't seem to link to them as this site will not allow me??
I am using it myself, as I had the same issue with my 2 GTX 260's.
Nov 01, 2008 | PNY XLR8 GeForce 8800GT 512MB PCI Express...
Auto adjustment.
Try this one:
the is not the same problem. But the cause is exactly the same
http://www.fixya.com/support/t117851-menu_screen_appears_all_time_flashes
Regards
Jan 28, 2008 | Neovo F-417 17" LCD Monitor
Gateway FX7026 PC Desktop Logo
307 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
