Plantronics Roth Music Cocoon MC4 iPod Dock, MC4C, Black w/silver, 7.5" x 7" x 5", Matches the iPod with the Cla...  Docking Station Logo
D
Dave Harmes Posted on Feb 01, 2016
Can a 8gb memory card be used - Plantronics Roth Music Cocoon MC4 iPod Dock, MC4C, Black w/silver, 7.5" x 7" x 5", Matches the iPod with the Cla... Docking Station
1helpful
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
SD card format ng no card
  • 1 Insert your SanDisk 8GB memory card into a card reader connected to your computer.
  • 2 Double-click "Macintosh HD" on your desktop.
  • 3 Click on the "Applications" folder, then the "Utilities" folder.
    4 Double-click "Disk Utility". Look on the left side to locate the drive that says "SanDisk.
    5 Select the capacity of the drive on the left side of the window. The capacity will state "8GB" or "8,388,608 kilobytes." Click on the "Erase" tab to format the memory card. When you see "SanDisk" listed as the device's name, the capacity will be located above. You need to select the capacity and not the device.
    6 Select the appropriate "Volume Format." Under the "Volume Format" button, select the format you wish to use. Select "Mac OS Extended" if the SanDisk 8GB will only be used on Macs, or "MS-DOS (FAT)" if you will share the card between a Mac and PC. Select "Erase" to complete the format of your SanDisk 8GB memory card.
    1helpful
    Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
    The manual lists the following SD cards compatible:
    4 GB SDHC Memory Card
    2 GB SD Memory Card
    1 GB SD Memory Card
    512 MB SD Memory Card
    256 MB SD Memory Card
    128 MB SD Memory Card
    64 MB SD Memory Card
    An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
    Thanks for using Fixya.
    1helpful
    2answers
    My 8gb microSDHC memory card fits in my phone, but no memory card shows up
    The memory card may have to be formatted for the phone with the phones format procedure via the PC and the proper software.
    3helpful
    Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
    No the Pentax Optio S5i does not support an 8gb memory card.
    8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
    Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
    My S5i locks up if you put an SDHD card in.
    The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
    How do i format a 8gb sandisk microsdhc card to my new samsung sgh-f480i mobile phone
    Use an adapter to put it in your PC, then use the windows format tool to format it as FAT32.
    1helpful
    Can I use a 8GB memory card in this phone?
    Yes, it should be able to handle it, but not any more than 8GB.
    Aug 31, 2009 • Cell Phones
    3helpful
    2answers
    Can I use a 8GB memory card in my sony C902
    The Sony Ericsson C902 does support up to 8GB memory card.
    Is there a way to upgrade the 700wx to use 8gb memory card?
    if its maximum capacity of the Palm Treo 700w... is 700wx you cannot use any memory card beyond that because it hang the programms,bt if its maximum capacity is beyond that then you can add 8gb memory card.
    1helpful
    My new 8gb sandisk says it is not formatted and I can't format it
    well i heard on another website - that because the memory card can hold alot of memory, the computer doesnt accept it, so you need to use a usb memory card reader, ebay sells it for like £1
    Top Plantronics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    SmartAviator
    SmartAviator
    Are you a Plantronics Audio Player and Recorder Expert? Answer questions, earn points and help others
