Re: My battery is fully charged, camera goes on and shuts...
This generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
The camera shuts itself down to protect itself for further damage since it detected a problem. Make sure your battery is fully charged. If yes, then do this little trick. Hold the camera with your right hand with the lens facing the ground. Next, tap the camera's base as you turn ON the camera. This aims to remove any grit of sand or dust stuck in between the camera's base and the side of lense barrel. You may have to do this several times and see it it works.
Please let me know how this goes. Thank you for using FixYa.
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at [email protected]
Verify you have the right kind of battery and fully charge it. The lense issue you describe commonly happens when the device cannot access enough power to function correctly, so it retracts and powers off to avoid getting your lense stuck in the 'out' position if the battery goes dry.
