Question about MSI K8MM-V Motherboard
V class n 1996 - MSI K8MM-V Motherboard
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Is that a question or a statement?
  • 205 Answers
V class n 1996
Posted on Aug 01, 2009
Where would I find the blower motor on a 1996 ford pace arrow
Is it a class A or class C ?
I think a class C would be under the dash on the passenger side.
Jul 05, 2013 | Cars & Trucks
How to connect ignition coil to spark plugs of a mercedes benz c class 1996 model
take the top cover off (says mercedes on it ) you will find (on a 4 cyl ) 4 separate coils nomally held in by 2 bolts and attatched to the LT wiring loom
Sep 16, 2010 | 1996 Mercedes-Benz C-Class
Best ways to keep my 1996 mercedes benz c class engine efficient
Oil changes every 6,000 miles with new filter too.
New spark plugs, HT leads and distributor cap every 12,000 miles.
Let it warm up properly in the morning before moving off.
Clean air filter or replace ever 12,000 miles.
Clean out the intake manifold with carb cleaner to remove nasty deposits.
That should help your engine last a very long time.
Hope this helps and vote for if you think so. Thanks
Jun 24, 2010 | 1996 Mercedes-Benz C-Class
Which oil type should i use for 1996 mercedes-benz c-class
1996 Mercedes Benz C Class
Engine Oil Type/Weight/Capacity
Application:
Oil for use in temperatures above 23 degrees
Note :
5 4/5 Quarts with filter change
945
Application:
Note :
Valvoline SynPower Full Synthetic
20W-50 Motor Oil
Hope helps (remember comment and rated this).
Have the diesel version 1996 e class. something
With the diesel engines you have to let the ignition coil warm up before you will have any luck cranking it. Diesel cars are no good in subzero temperatures. I had the same problem with my 92 300D Turbo and when i took it to MB they told me it was because i wasnt letting the coils heat up long enough.
Feb 11, 2010 | 1996 Mercedes-Benz E-Class
Sluggish C-Class Wiper
had this problem on mine as well, the MB agents put grease on the mechanism, take out the cover and put some grease in there
Dec 07, 2009 | 1996 Mercedes-Benz C-Class
Merc c class heater problems centre blowing cold and sides hot
Bad vacuum pod, try using a mini vacuum and the on the valve block behind the glove box take suction on each one till you find the bad one.
Jun 10, 2009 | 1996 Mercedes-Benz C-Class
1996 mercedes E-CLASS ABS LIGHTS ON AS I START TO DRIVE
you should be able to pulse the pump in actuator tests you can test the signal at the same time.your cruise wont work if the abs isnt working it takes the readings from the wheels,check your power and earths at the pump.
Dec 29, 2008 | 1996 Mercedes-Benz E-Class
MSI K8MM-V Motherboard Logo
121 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
