Question about Panasonic Televison & Video
Green line in middle of tv when switched on - Panasonic Televison & Video
    Novelist:
  • 123 Answers
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Posted on Jul 15, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
60inch lg plasma green line down the middle
Visit this site named 'Electro-help' These type of fault to plasma TVs are described in detail there. Almost all plasma TVs will have same structured circuits. You can find which board to your TV is faulty, by referring details from this site. Check this link, and select the site named above. Pull up older posts there.
Jul 30, 2012 | LG 60PS60 60 in. Plasma HDTV
A line has appeared across the bottom of the screen and also along the middle. the bottom line is white/red.blue and the middle line is mainly green
If your TV is still under guarantee then change it asap, if not you have a problem, the panel has failed, in very rare cases the lines will disappear when the set is at its maximum operating temperature, that said it will never be 100% again, sorry
Apr 19, 2010 | Grundig GU26DVD 26 in. LCD TV/DVD Combo
Sony 43 inch rear projection tv, I have lined up the convergence but still seeing red and green around edge of the tv on the images, seems fine in the middle of the screen though.
Always start at the vary center of the screen with Green. Position Red over Green, then Blue over what now will look yellow. If all is perfect except the outside, you will need to adjust "Mid-Size" until the middle is just as far off as the outside lines. Then adjust the main "Size" adustments to match. Go very slow or you can make a mess of it.
Mar 06, 2009 | Sony KP-51HW40 51" Rear Projection...
Green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Oct 19, 2008 | RCA 20F512T 20" TV
RCA TV GEMSTAR GUIDE PLUS GOLD
what is this TV's modle #?
Aug 24, 2008 | RCA F32650 32" TV
Power
Sounds to me like its your green tube. Kind of expensive replacement, but easy.
Jul 24, 2008 | Sony KP-51HW40 51" Rear Projection...
TV has line down the middle
Remove the front sceen and check for a cob web acrossone of the px tubes, is one possible cause of your problem.
Jun 15, 2007 | Panasonic PT-47XD64 47" Rear Projection...
TV HAS AN OCCASIONAL GREEN LINE THROUGH THE MIDDLE OF THE SCREEN
The verticle output IC has a bad connection on it or is going bad. There are no user replaceable parts inside this set, as its a solid state set and all parts are soldered in. If your aware of the HI voltage issues, and know how to do alighnments on a tv, then you can order the entire board as a module from http://www.ptscorp.com. If you dont then your gonna have to seek a pro to assist you in this repair, as these sets hold HI voltage inside thenm even after they have been unplugged. Good Luck
Jun 25, 2006 | Zenith SY2779DT TV
Televison & Video Logo
314 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
