SOURCE: 1989 sportster building pressure in oil tank
A little pressure is normal on the sportster. I have seen where if the oil tank is over full it can blow the dip stick out. Most of us who ride sportsters keep the level showing on the dip stick about midway between the low and full line. Doing this will also help with oil blow by out the air cleaner.
SOURCE: Oil Dipstick tube is broke, Where does it go?
http://carservicemanuals.blogspot.com/2008/06/download-dodge-ram-2005-service-manual.html
SOURCE: 83 Ford F350 Diesel Dually Smoking from oil
I have an old IDI 6.9 diesel. They tend to burn oil, and that would be normal. Just keep a check on your fluids, and unless the smoke is excessive it should not be a problem. I must say though, I personally think the IDI's were the best diesels ever built. They last forever. If you really want to treat your truck to a nice treat, after you fill your tank, dump a quart of auto trans fluid in the fuel. The additives, cleaners,and lubricants in the trans fluid really help to clean all the carbon and build up out of the injection pump, and clean the gunk from the valves and cyllinders. I usually do it every other month or so.
SOURCE: my engine oil dipstick missing
remove the 13mm tube bolt, and the wireharness, raise vehicle drain oil, move filter, remove the flywheel cover 2 10mm bolts abd 1 18 mm bolt swing out of way remove 2 10mm nuts and 13 or so 10mm bolts, drop oil pan spray pb blaster or whatever you like to use around the top and inside of where the tube sets, get a rubber mallet tap it out, it will be hard because it will be rusty but itll come, took me n hour and a half to do everything longest part being getting the tube out put a new gasket on with atv to hold it on the engine also put atv on anywhere metal joins '-' torqe is 105 in lbs no squence place flywheel cover pu on filter fill with oil
