Question about PC Desktops
Data Transfer from hard dick.
I paid a computer repair centre to copy the disk info onto a CD Rom.
I fitted a new hard drive and loaded XP. Also Office 2003. The computer works fine. Also connected to the Internet.
The CD Rom was located into its drawer and the drive is allocated 'E'.
The information on the old hard drive and the CD Rom is an accounting programme and the datafiles.
Through Windows Explorer, I located the setup icon for the programme. I doubled clicked and it copied files to C. When I click the short cut icon for the programme, the programme window opens. The next thing, a message appears stating it 'Can't get into a file in the e: drive.
So I un-installed the programme and copied the whole of the CD onto a file in C/ Programes/. I opend the file and once again setup the programme.
Selected the Programme icon. and it still looked for a file in e:
The problem I had with the original hard disk was when the computer booted up, a message appeared like 'Bott file missing, please load system disk.
Any ideas.
  • 324 Answers
Re: Data Transfer from hard dick.
Unfortunately, this doesn't sound like a good situation, or exactly what you want to hear. It sounds like there was some corruption to a program file as it was copied to the CD during backup. That is pretty well confirmed by the fact that you can't access the data from either the CD or the copy of the CD.
About the only thing that I can suggest is to try to obtain an original copy of the program that you are using and load that. Then try to access the individual data files through the newly loaded program. You may have to copy them into the program for this access.
If the data is worth it, you might be able to contact a company that specializes in data recovery. I've never had to use one, but my understanding is that they are quite expensive. If you want me to research those costs, please let me know.
I might also suggest that you attempt to recover what the company that did this for you (to you!) charged you for the copying service. They apparently didn't do you any favors and should refund the amount to you.
Please don't beat me up on my rating just because There is no way to easily recover this data.... ;o)
Sorry, I wish there was a better answer to give you.
Posted on Nov 17, 2007
0 characters
3 Points
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
Jan 02, 2011 | E-Machines eMachines Desktop PC
NTLDR is missing?
A missing NTLDR is a common start up error that can appear on the screen while booting a computer running a Windows operating system. This error may occur due to number of reasons.
NTLDR is short for Windows 'NT LoaDeR'. It's entirely involved in the loading of the operating system.
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk/hard drive that contains no operating system or CD-ROM drive. Firstly what you've got to to is press the Delete key multiple times as your computer boots up until it displays the BIOS screen. Then you will need to find the boot disk priority setting. Make sure this is set to your drive that has Windows on it (as priority 1) and not the CD-ROM drive/stiffy drive or empty hard drive. You can set the CD-ROM/DVD-Rom drive to priority 2 if you like.
Once you have checked that and have set it to your master/primary hard drive (the one that you've installed Windows onto), save and exit the BIOS and on reboot your system should boot into Windows normally.
If you only have one hard drive and the boot disk priority 1 is set to it and you still get this message, then it means that your NTLDR is either corrupted or missing. In the BIOS you will need to change boot disk priority 1 to your CD/DVD drive. Once this is done save and exit the BIOS.
As the PC reboots insert your Windows install disk and let it load.
Hit [R] when prompted if you need to repair system files and then [C] at the 'Welcome to Setup' screen to start the Recovery Console. This will let you copy NTLDR from the CD to C:\
If this fails then you will need to install a fresh copy of Windows on your system. All is not lost though as you can still save your data that is trapped on the NTLDR missing hard drive. If you are not quite seasoned with computers and electronics then this is the job for a PC technition. Simply take your PC down to your local Computer store and explain your situation (Don't forget to take your original Microsoft Windows with you). They will back up your data, re-install Windows and the put all your data back on for you.
on Nov 15, 2010 | PC Desktops
I have an HP Pavilion dv6-1230us notebook. I noticed some skipping on my programs so decided to restart my computer. Upon restarting it I ended up with a startup failure screen, so I had it launch startup...
Get a new drive in a caddy and boot your computer within safe mode (press F8 as it loads).
Copy all you can to the new drive.
If you cannot do that, buy a replacement hard drive and load your system disk in the CD Rom drive booting from it. When the system is loaded and running, power the desktop down, fit the old drive and set the jumper as SLAVE.
Boot up your desktop and there will be what is left of your data on drive D. Copy all you require before it is too late!
Hope that helps.
Dec 09, 2010 | HP Pavilion 505n (DC470A#ABA) PC Desktop
Transfer info from this computer to my new comp. things like Pictures Music.
Copy all your data from the old computer onto a blank CD, blank DVD, or onto a USB flash drive, or external hard drive. Then copy it to the new computer.
When both computers are in the same location, you can use an Ethernet cable to transfer information between machines. If you don’t have a hub, router, or switch, look for a crossover cable to complete the process.
Jun 23, 2010 | Dell OptiPlex GX270 PC Desktop
Missing or corrupt hal.dll file, so can't boot the hard drive
Please use the recovery discs or windows installation cd.
To either perform a full system restore with the recovery discs.
Or to perform a repair installation with the windows installation cd.
Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Thanks and good luck.
May 03, 2009 | Dell Dimension 3100 PC Desktop
How to get files from old computer to transfer to new one
u can take backup of data by harddisk to harddisk.
Connect your old computer harddisk to new computer then simply power up the new computer then u find both harddik then simply take backup of old data to new computer.
Apr 22, 2009 | PC Desktops
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
Just purchased IBM Intelistation 6221..installing windows????
hi! try this. reboot your cpu, then press the CMOS setup key (del), then select load default setting, then go to hard disk detection settings, select the LBA setup. I believe you know how to manipulate the CMOS setup configuration. if still doesn't work out, bring it to the service center near you and ask for assistance, Im sure they would love to help you. Have a nice day!
Dec 20, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
My compaq desktop computer wont start up it keeps saying NTLDR missing
you have to repair the operating system or re-install it
Aug 16, 2008 | Compaq PC Desktops
Compaq Deskpro EN contant restarting when attempting to load XP
Last time this happened to me, I had to reformat and reinstall windows. I tried all those modes, and I even tried the windows repair. None of that worked, I just did a complete new install. All of the data will be lost, if you do this.
My advice, if you need some of the data on that hard drive, you need to hook the drive up to another computer and backup what you need.
Or buy another hard drive, install windows on the new drive. Now slave the old and backup the data.
Nov 11, 2007 | Compaq Deskpro EN PC Desktop
PC Desktops Logo
134 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
