Question about HP LaserJet P3005n Printer
My P3005N printer is making a squeaking noise and it folds the top left (when looking at the printed sheet) corner of the sheet on nearly half the printed copies. I have cleaned the roller with an alcohol wipe and that seems to help but is there anything else I can do? The printer is about 2 years old and this started about 3-4 months ago. Should I replace the roller or what? Thanks for your help with this. Charlie
    President:
  • 3,085 Answers
You most likely have a worn out FUSER.
Posted on Jul 15, 2009
How can I print booklets?
One sheet booklets generally are two-sided printing jobs, accordion fold, gate fold or quarter or half fold styles. Determine which of these styles your's will be and make a "dummy"....it's as simple as folding the paper according to its finished form and marking each of the panels with scaled type or pictures. By making the dummy, the layout will reveal itself when opened and flattened. You will most likely have to "flip" the pages and print each side at separate times unless your machine is a "duplex" type of printer. The "dummy" is the key to the puzzle. Simple as folding and unfolding the panels.
Jan 30, 2011 | Canon LASER SHOT LBP-2900 Printer
My printer will not print from my lap top. Printer will let me copy, but not print from the computer. Someone suggested that I uninstall and then reinstall program, but I cannot locate the disk. Anyone...
If it worked fine and it indicates a ppaper jam, open the top of the printer and check the left and right corner where the rollers are to make sure their is not a piece from a corner of a sheet. A small piece of paper will give paper jam.
Unplug the printer, replug back in. It should work. If not, open the back to make sure their is not a sheet sutck there by accident. thanks
Mar 11, 2010 | HP PSC 1315 All-In-One InkJet Printer
When I am faxing do I put the paper print side up or down?
Most printers are different even from the same monufacturer. The easiest way to tell is look for the icon near the place where you load the fax. There is what appears to be a sheet of paper with a corner folded over. If the icon shows lines across the main part of the icon, and there are no lines on the part that is folded over, then the paper goes in the machine face up, or lines up. If there are no lines on the main part of the icon but there are lines on the part that is folded over, then it signifies the paper being loaded face down, or lines down.
Sep 12, 2009 | Canon L120 Fax Laser Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Feb 17, 2009 | HP LaserJet CP3505n Printer
Sheet is not been detected
Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer......  Good Luck
Jan 17, 2009 | HP LaserJet 1100 Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Paper jammed
I had exactly the same problem, printer virtually new, printed great for a couple of weeks, then today refused to take paper with E3 flashing. No apparent blockage - all looked clean, tried all the utilities, roller cleaning and plate cleaning, but wouldn't take paper!
Solved it by moving the paper size guide all the way to the left, then folding the top 20mm of a sheet of A4 over and loading it so fold is at the top facing you. This acts as a catcher for anything stuck in the printer. Hold the paper slightly crooked with the left side slightly further into the printer and press the copy button (with nothing in the scanner!). It should draw the paper in now (with some persuasion) and think it is printing (it's blank,of course). Check as the top of the sheet goes in that the fold is still tight and doesn't open up as it feeds in. Lo and behold, mine brought out a 5p piece - printer now prints perfectly!
Mar 20, 2008 | HP LaserJet 2100 Printer
Printer
mybe u put a lot of paper .try to put just one and place the paper holder to the left side of the paper
Dec 19, 2007 | Canon PIXMA MP210 Photo All-In-One Printer
HP LaserJet P3005n Printer Logo
264 people viewed this question
Seeker5211
Seeker5211
