Question about HP Photosmart 2710 All-In-One InkJet Printer
Carriage screeches and stops
I've aligned it and there are still jagged lines and noise with the carriage
SOURCE:
SOURCE: Carriage Jam
I FIXED MINE YES... open your thing.. and look,... do you notice..
theirs like a small black.. corner shaped thing, that stopped the carriage..
pop that thing like add force to push it back...
boo ya. :) and their you go...
this problem annoyed me for a month. and i went through numerous hp printers too.
but, just...... really open your eyes and try to find out whatsup..
:) woot woot woot imma print stuff now.
Posted on May 11, 2008
Khalsa007
  • 79 Answers
SOURCE: Carriage jam error
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7 Allow the all-in-one to re-initialize. This may take a minute or two.
8 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Thanks
Posted on Jun 04, 2008
My solution was to simply unplug the unit, with leaving it off for several moments. Voila! It worked!! I had to reset the time and date settings, though. A small price to pay.
Posted on Jul 07, 2008
komguy
  • 2306 Answers
SOURCE: carriage jam
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Posted on Jan 15, 2010
  • 685 Answers
SOURCE: Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Posted on Feb 12, 2010
Grinding noise from front wheel
something is not aligned right take the wheel off that is causing the noise and check the carriage
Jan 20, 2014 | Plymouth Voyager Cars & Trucks
I've got vertical line on my photos
Just one, or many? Could be needing a new ink cartridge. If its just one, possible your carriage is having an issue, or your paper.
Aug 30, 2012 | Epson Stylus Sx400
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Rear end noise On a street rod
It could well prove to be a big job? by the sounds of it I would get it to a Jag dealer or indi Jag garage to be looked at properly.
It might mean that you need a new or second hand IRS unit.
Jun 02, 2009 | 1995 Jaguar XJ6
Jagged lines in draft mode
hi, it sounds like the head needs alignment. nLook in the manual, follow the proceedure outlined there and the problem should disappear
Feb 14, 2009 | HP Designjet 90 InkJet Printer
HP Officejet 7410 noisy carriage
The issue  is with the hardware of the machine itself so basic trouble shooting may not hepl to get rid  of the unwanted noises.
Jan 26, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Horizontal red lines when printing
Horizontal line is carriage axis , while moving its may give line if some dust or resdual ink may be on he carriage base
clean the caping station and cleaning wiper ( place where carriage rests )
if its not resolved please update sample images for same
May 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Alignment problems
Here's the deal with the cartridge alignment page....the machine will spit out a series of black lines mixed with yellow ink and at the beginning of each of these lines is a "Green" check mark. The carriage moves back and forth over these lines and green check marks and reads them by use of what is called a "spot sensor" that resides on the right side of the carriage assembly. This is usually noticed by the blue ray of light that shines out of it. So if you are getting an alignment failure one of two things is happening....1)You've have got a bad cartridge (usually the color) and it is not laying down the right colors, specifically the green check mark or 2)You've got a bad spot sensor...even though it may still be shining the blue light, the sensor board can't process the information. Its an easy fix either way.
Inkworks
Apr 25, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Printer alignment
Inkworks
Apr 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
48 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
