Question about Dell 1700 Laser Printer
2 Dell 1700 printers both have started jamming pages
Coincidently 2 1700's bought and used same amout of time have started jamming. As soon as you go to print 1 page gets stuck in tray. Open tray straighten out and most time will continue. Is it fixable
  • 25 Answers
Easy fix. Replace the pick up rollers. There cheap and easy to replace. It make perfect sense, bought at the same time and use the same amount then the pick up rollers are going to wear out causing paperjams at the same time.
Posted on Jul 16, 2009
Keep getting "Printer Offline" from Dell 1700 printer
go to the start menu
click on run
type services.msc
on the list go to Print Spooler
double click on print spooler and select automatic on startup type
now press on start.
if that doesn't work go to this microsoft website and click on the Fix It icon with the little man holding a wrench. run this and it will fix it.
Dec 03, 2009 | Dell 1700n Laser Printer
Our printer is having paper jams in the back we have cleaned the printer and took it apart to see what was wrong and it still keeps happening is there anywhere we can take it to
You may have some luck trying some of the tricks found here. I have a 1700 myself, but don't use it much...works great when I do thou!
Aug 13, 2009 | Dell 1700 Laser Printer
Ink on the edge of the page everytime we print a document.  we refill our toner, but have done so for years.  dell says that it is bc of the refilling and that it has filled up our drum??? any...
The Dell 1700 cartridge can leak from a failed mylar blade that sits against the Developer Roller.
The plastic locking ring on the and of the Developer roller spindle (of the toner cartridge) can come loose, or break (over time).
The drum unit has a relatively low capacity to hold waste toner, and all toner is not the same (waste toner shouldn't be re-used - it will just fill up the waste section of the drum even faster). Some toners are more efficient than others.
If you reset the 'replace drum' indication, without actually replacing it (or at least emptying it) you will soon have the drum over-full of waste toner, and the only other place it can go then, is inside the printer, and onto the paper.
Jun 23, 2009 | Dell 1700 Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
System shuts down when printing to dell 1700 laser printer
You may have a 'recalled printer' Check out this link!
http://support.dell.com/support/batteryrecall/index.aspx/en/main 1700/1700n Printer RecallIn cooperation with the U.S. Consumer Product Safety Commission, Dell is voluntarily providing the Customers who purchased the 1700/1700n printer (from June 8th, 2004 - August 18th, 2004) a free replacement printer. [Announced September 7, 2004]
May 11, 2009 | Dell 1700 Laser Printer
Dell 1700
I've experienced this in the past and found a paper jam in the back feed roller and had to take the unit apart to retreave document. Try doing this (only if no longer under warranty) there are a few screws in the front and it should be able to come off easily.
Nov 10, 2008 | Dell 1710n Laser Printer
Dell 1700 prints test page on enlarged print over 4 pages
It sounds as if it's set to print in poster format,
1 From the computer’s software application, select File then Print.
2 Click Properties (or Options, Printer, or Setup, depending on the application) to view the
printer driver settings.
3 From the Page Layout tab, click More Page Layout Options.
Aug 30, 2008 | Dell 1700n Laser Printer
I have a dell 1700 laser load paper lite and ont print from tray
sure..it's in the printer control panel, under paper source. Open that up, and you'l lmost likely find that it's on a default. Also, do a print test page under admin, prior to doing any print jobs.
http://www.kauaikeepsakes.com/computerguy/
has an option for a Free demo of a Shared Screen session.
Jan 24, 2008 | Dell 1700 Laser Printer
Dell 1700 Transfer Roller
These series printers have a typical problem of the paper pickup rollers wearing out resulting in jams, crooked feeds and partial feeds. a quick fix:
take the paper tray out, turn the printer on edge and locate those two rubber roller bands on the pickup arm. Peel them off, flip them inside-out and return them to the rollers. This restores thier sticky rubber side so the papper feeds properly.
Now if you are a heavy printer, you can order some of these from dell for the next time. Washing these in handsaop and water works sometimes too. never use alcohol.
Jan 06, 2008 | Dell 1700n Laser Printer
Dell 1700 Laser Printer Logo
112 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
