Question about Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW says no paper when trying to print. there is paper, it will make copies and test page, but beeps and flashes no paper when printing. Says "reload paper in MP tray", I've taken out all paper, reloaded it, turn the machine on and off... HELP!!!?????!!!
  • jlkill May 11, 2010
    I have the same problem and do not see the solution here. Any ideas?
I had this problem trying to print from MS Word in a template I downloaded. I found this link and it worked perfectly. I'm using Word 2010 so I had to adjust accordingly. It's for a slightly earlier Brother model but that did not affect my using it.
Posted on Nov 30, 2010
I had the same problem and in trying to troubleshoot it, I found out it was getting "No Paper" with just one Word document. I went into "Page Setup" and then "Page" for that document, found paper sources were set to "Manual", changed them both to "Page 1", then re-sent document to print and it worked!
Posted on Oct 24, 2011
  • Phil Hormel
    Phil Hormel Nov 07, 2011
    To clarify - I meant change it to "Tray 1", not "Page 1". "Auto Select" and "Default Tray" will also work. The problem was for the document the page source was set "Manual"...
MP tray stands for MultiPurpose tray. Whatever document you are trying to print is set to print from the multipurpose tray that opens up from the front of the printer. You need to adjust this setting in your software's print settings.
Posted on Aug 11, 2009
Usually this is due to incorrect setting for Paper Tray in the printer, Fax or Copier configuration. I had the same problem which got resolved after I reset the configuration to select Tray-1 (T1) as the first source for paper.
Hope this helps.
Posted on Mar 04, 2010
My printer was doing the same thing!! I did not change configurations such as tray source so it finally instructed me to pull tray 1 completely out and i found that a paper was jammed aaaallll the way in the back of the machine, I was not able to see even when I opened back of printer, I turned printer off after removing paper and problem was solved...Hope this can help someone!!
Posted on Sep 22, 2009
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
http://download.brother.com/welcome/doc002258/mfc9840_uk_usr_b.pdf
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
Suddenly, our Brother MFC 9840cdw keeps spinning its top paper feed rollers, forevier, and says Fax Only, Please Wait. When we press the Copy or Print buttons to get out of Fax mode, nothing happens. I...
It does sound like a paper sensor in the automatic document feeder may be stuck and the machine keeps trying to eject the paper that is not there. I have not seen this before, you may have to call Brother at 1-877-BROTHER to find the nearest service center.
Jun 02, 2011 | Brother MFC-9840CDW Laser Printer
Loud clicking noise on MFC 9840CDW. like gear not engaging
Hi, Jane,
Saw your post--here's a place to start.
This annoying behavior can occur when the paper tray sizing latch is incorrectly set or left in an unlocked state. Try this: 1) Remove the paper tray from the machine. 2) Inspect the back/rear of the tray--you'll see an adjustable latch (blue on some models). 3) Pinch and slide the latch to acommodate snugly your preferred paper size--for US users, it's typicaly LTR (letter-size); be sure the latch is secure. 4) Reinsert the paper tray (filled with 20-lb paper), turn the machine off and, after 30 secs, turn it on again; now, print a single page or a test page. You should be good to go.
For those with an installed auxiliary paper tray (lower, second tray), the latch on this tray should be checked as well; while the aux (lower) tray latch may differ slightly, the same remedy applies.
The problem can be attributed to insufficient precision in Brother's tray design. Just a small quirk...
Report back if issues persist.
--BAM
Jan 22, 2011 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW not printing colours properly
Always use Brother toners. This is a common issue with cheap copies and remanufactured cartridges.
Jun 08, 2017 | Brother MFC-9840CDW Laser Printer
Brother MFC 9840CDW
Sometimes just a static shock can do that, you need to replace the control panel pcb to fix it.
Dec 24, 2009 | Brother MFC-9840CDW Laser Printer
I have a brother mfc-9840cdw. The error "print unable 20" has appeared. Printer is 1.5 years old and has printed 5,000 pages.
Hi there !!
Thank you for choosing fixya.com
Try to reset the Printer settings to default & the try:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000005/faq000105_008.html?reg=us&c=us&lang=en&prod=mfc9840cdw_all
You can also do search the knowledge base for brother printers.
Hope this would help,
Regard's
Anurag Shukla
Sep 08, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW Wireless printing on Vista
maybe is not configured to work with vista;s sorry.
Mar 19, 2009 | Brother MFC-9840CDW Laser Printer
MFC 9840cdw
look at the drum, that's going to be where you will find the dots on...
Jul 31, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9840CDW Laser Printer Logo
4,111 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
