Maytag MAH-24 gives dl fault when attempting to operate. Unit is two or three years old, but is in a custom built RV and has never operated. It has never operated because the RV has been under construction until recently.
  • merlinlib Jul 17, 2009
    Of course there are no coins in the machine and no water since, as stated, the unit has never operated.
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.
Please unplug the machine. Tip the machine back. Take the plastic cover loose from the bottom front of the machine. There are 4 screws on the right front side of the machine that form a square. Remove those and take the spring clamps off the pump hoses and wire connector. Whatever water that is in the machine will come out, have a bucket or shop vac ready. The coins or other foreign objects that are in the pump can now be removed.
A few points, however.
1) You don't need to tip the washer entirely on its side, but you need to tip it enough that you can access the bottom of the washer.
2) It's not trivial to get the plastic cover off the bottom of the unit. However, if you fiddle with it enough, you'll eventually get it off.
3) My MAH2400 had five screws on the bottom, not four. That's a pretty obvious issue to deal with.
4) If the coins have been in the pump for a long enough time, it may have chewed up the pump blade. If you're able to get the coins out, then you can also replace the pump. The following link provides a source for a replacement part:
http://www.partselect.com/MultiModels.aspx?ModelNum=MAH2400&searchTerm=&RefineSearch=0
5) The post that includes the previous link also provides a schematic if you want to see what you're doing:
Here's a link for the steps with pictures:
http://blog.myspace.com/index.cfm?fuseaction=blog.view&friendID=58843118&blogID=364038999
Hope this helps
God Bless
Posted on Jul 15, 2009
  • Aparajita Batabyal
    Aparajita Batabyal Jul 17, 2009
    Okie the specific meaning of the DL error is Open door lock switch with motor running.
    The action item to be done is :
    Check for loose
    wire connections
    Clear the diagnostic
    code and recheck;
    if reoccurs, perform
    Diagnostic
    Motor/Machine
    Control Board test
    Check for faulty
    motor relay on the
    machine control
    board.
    Check out page 12 in the manual from the bellow link:
    http://www.servicematters.com/maytag_lib...
    Thanks
What does error code LF on my Maytag 2000 series front load washer mean?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 03, 2014 | Maytag Washing Machines
Suburban SF30FQ furnace doesn't run. Has power to unit and can hear relay click in unit when call for heat but blower does not run.
Please give make, model, year etc of RV that furnace is in. Thermostat on wall operates heat and cool?
Oct 10, 2013 | Dometic Rooftop RV Air Conditioner
I have a 13 year old Maytag that works great. But recently the flipper door that dispences the dry detergent doesn't open during the wash cycle. I've tried cleaning it thoroughly, but that hasn't made a...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 17, 2010 | Maytag 24 in. MDB6600A Jetclean II...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Fault light flashing,
Is it please possible for you to add additional comments in your query about dishwasher problem
1. make and model number of dishwasher
2. are there any fault codes or lights showing up - which ones
3. at what cycle does the operation stop - eg still washing and there is water in dishwasher - is it warm/ cold, rinse is starting (can hear the pump) but stops halfway, rinse is complete but does not dry..
4. how old is the unit
clarification on above will help understand the problem better.
Jan 03, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Maytag Dishwasher MDBH965AW No Power
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Maytag Dishwasher MDBH965AW will not power.
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Need year
I called Maytag customer service about my dwu9200aae last week and with the serial number they were able to give me both a month and year made.
Mar 31, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Maytag diswasher won't spray water
water level/float switch is stuck. (dishwasher is getting a indication the unit has enough water in it to operate)...repair/replace float switch, located in front right corner under bottom rack.
clarkco
Feb 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Neptune MAH-3 front load wasehr
Dear kimlrgh
ngfam at you service!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Aug 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
