Question about Sharp MX-2300N Color Copier
We just got an MX-2300N and are trying to set it
We just got an MX-2300N (a few hours ago to be exact) and are trying to set it up. When we try to set up the SMTP and POP3 server we get the error: "ERROR[3332]: Connection to SMTP server test failed." The Details are: "(POP3)Connection failed." The tech from the company we bought it from can't figure it out. We are using a Linux server running sendmail for our email. Could that be what's causing the problem? We've tried different usernames but we always get the same error. Our email itself is working fine so we know the server is working. Thanks for your help.
  • 29 Answers
I had the same issue the other day when installing one of these machines.
I find it alot easier to enter the details into the machine from it's web interface if you aren't already.. (Simply open your web browser and navigate to your copiers IP address).
If you ping the domain name of your mail smtp server and just get the servers i.p address and enter into the smtp box it should work. The particular one i used didnt need authentication either, give it a whirl and see how it goes.
Posted on Aug 19, 2009
Sharp MX-2300N error DK - which drum part number?
It looks like they are the same regardless what color you need to replace. Just buy one and go with it. Here is an example from amazon: http://www.amazon.com/SHARP-MX-2300N-1-COLOR-DRUM-MX27NUSA/dp/B00AA961GI/ref=sr_1_2?s=electronics&ie=UTF8&qid=1425339155&sr=1-2&keywords=sharp+mx2300n+drum
You can also contact a local specialized provider such as Cartridge World who can find exactly what you need for you.
Mar 02, 2015 | Sharp MX-2300N Color Copier
Sharp mx 2300N error code U2-41
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Oct 16, 2014 | Sharp MX-2300N Color Copier
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
Apr 19, 2014 | Sharp MX-2300N Color Copier
Prints B&W but not color...
Try reinstalling print driver, or upload a PCL5e driver.
Feb 16, 2018 | Sharp MX-2300N Color Copier
Sharp MX-2300N - can only print on computer restart
You will have to contact Sharp's service department.
Apr 30, 2012 | Sharp MX-2300N Color Copier
SHARP MX 2300N Have cleaned the glass but still
Try cleaning the smaller part of the glass on the machine located to the left hand side of this machine!
Aug 25, 2011 | Sharp MX-2300N Color Copier
MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
May 18, 2010 | Sharp MX-2300N Color Copier
Mx-2300n network error ce-00 when trying to scan to email?
Using Internet Browser access to the Printer/scanner, accessing Network settings, I noticed that the "Connection Test", (below the SMTP Settings), would not go through when SMTP Authentification was set to "ON". Turning it "OFF" allowed the connection test to succeed, but did not change the error code.
However, adding a secondary SMTP Server, allowed it to go through, (leaving SMTP Authentication set to "ON").
Good Luck
May 03, 2010 | Sharp MX-2300N Color Copier
Sharp MX-2300N trying to send image to email address gives error
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Nov 21, 2008 | Sharp MX-2300N Color Copier
Sharp MX-2300N Color Copier Logo
6,040 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
