Question about Zebra LP 2844-Z Thermal Label Printer
Printer port configuration and Zebra trouble
I'm having a tough time here. I have an HP C7180 & a Zebra LP-2944-Z printer connected to the computer. I use the HP for invoices, and the Zebra for postage labels. In attempting to configure ports, they somehow ended up on the same USB port. I really don't know how I managed that. When I try a test-print on the Zebra, the HP goes to print a page.
I need to know how to decombine the port sharing, and then, this, my first - REAL - problem:
A computer-savvy friend helped me reload Win XP Home. Afterward, my Zebra stopped working. I DL'd & installed the current driver from Eltron/Zebra's website. Still, the thing won't print (was set to USB002).
Running the XP troubleshooter proved unhelpful.
Any help will be greatly appreciated.
Charlie
    Scholar:
  • 62 Answers
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Posted on Aug 02, 2009
    Champion:
  • Zebra Expert
  • 285 Answers
Dowload new driver ( go to www.seagullscientific.com) download the especific driver.
unplug the printer from computer. plug in again,
go to Printers and Faxs, , check if the printer icon is there, Rigth click on the printer, go to properties, print test page.
Posted on Nov 12, 2010
    Champion:
  • 254 Answers
Try the windows driver from seagullscientific
www.seagullscientific.com may be it will solve your problem.
Posted on Sep 03, 2009
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
My zebra lp2824 barcode printer does not print, i downloaded zebra lp 2824 from nice label still it not working, when doing print test it will print only some letters....what to do
check the driver, and the setings from the driver. Try ZDesign Driver or seggul driver from WWW.seaguscientific.com, and print the testpage, chech the connection (port) if is seria (com) check the setings speed etc...
Nov 09, 2010 | Zebra Eltron LP 2824 Thermal Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
How to configure zebra lp 2844 to ups shipping
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.html
Download the entire manual with this link.
Hope this helps! If so, please leave a rating!
Mar 10, 2010 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
Can't get it to print from usb port
the usb port might be dead.... try LPT or DB9 cable . if you reallly need the USB then you have to change the Main logic board
Jan 13, 2010 | Zebra LP 2844 Thermal Printer
LP2844 printer only prints after reboot
not yet sure if this is a permanent soln- but i was having the same problem with my wirelessly networked HP L7780. it would queue jobs, but show the printer as offline and only print queued jobs during a reboot.
i went to the printer properties (as detailed by PABLOCSA) and _unchecked_ SNMP Status Enabled (as suggested on another forum). doing so immediatly started printing spooled jobs... but i'm not yet sure if this is a long term fix.
Oct 03, 2008 | Zebra LP 2844 Thermal Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 parallel communication problem
The printer is installed on the PC using a specific port. If it's installed on the USB port, it won't work on the parallel port. Do you have this printer installed 3 different times? Need more details such as how was it installed the first time? And if it's working on the other 2 ports, why does it have to work on the parallel?
Apr 15, 2008 | Zebra LP 2844 Thermal Printer
Open Questions:
See all Zebra LP 2844-Z Thermal Label Printer Questions
Zebra LP 2844-Z Thermal Label Printer Logo
1,601 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
