Panasonic CT-32SL13 32" TV
Problem for Panasonic CT-32SL13 32" TV
Tv wont switch on
By mizz_cat_jon on Jul 15, 2009
my tv isnt working i put it on at the switch then press the button on the tv and nothing happenes has the fuse gone in the tv or in the plug plz help
Best Solution
posted on Jul 15, 2009
Very Helpful)
pegasus_four
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 148 votes
This could be a problem with the power supply. Yes there is a fuse on the power supply & if you have a multi-meter & are competent with electrical safety, you could test it. However, if it has blown then almost certainly something else will have caused it. You might have a short circuit bridge rectifier or faulty chopper transistor. If the fuse is ok, then you will need to check voltages from the power supply to find out what feeds you have. There may be a start resistor open circuit for example. If most of the start up voltages are ok, then you need to look at the line output stage & check if this circuit is getting any voltage supply.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Panasonic CT-32SL13 32" TV
Questions and Unsolved Problems for Panasonic CT-32SL13 32" TV
Do you recommend Panasonic CT-32SL13 32" TV?
Answer
Answer
tv will not turn on. TV seems to be attempting to power on. both red and green lights on front of tv... (More)
Answer
Need parts for Dynex TV model ''DX-R32TV'' main board,power board etc.
Answer
Well bought this TV; (Panasonic CT-32SL13 32") a while ago off of a friend, worked great up... (More)
Answer
How to change the fuse on a panasonic CT-32SL13G - FixYa
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic CT-32SL13 32" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
