Cars & Trucks Logo
Posted on Jul 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Passenger side shoulder strap doesn't tension properly on 88Vette
The passenger side shoulder/chest strap doesn't apply tension. The seat belt works properly but the chest strap does nothing - just flops around. I've tried adjusting the cinch lock but that didn't help. Any suggestions on repair?
Anonymous
Level 2:
  • Expert 161 Answers
  • Posted on Aug 27, 2009
Anonymous
Expert
Level 2:
Answers
161
Questions
0
Helped
49006
Points
327
Have you checked the tension when the brakes are being applied some of the newer vehicle seat belts don't tighten until you step on the brakes
1helpful
I can't figure out where the black retractor for the shoulder belts gets mounted. Stock belts. I took them out, but back in?
If you are referring to the front seat passenger seat belts, the shoulder belt retractors are mounted to the floor at the base of the driver and passenger side door pillars. They are usually hidden behind the pillar trim panel and the belt comes out thru a slot in the trim piece near the swivel.
How to remove a back seat from 02 toyota avensis
Hi, peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat.
Extend the set belts to their maximum length and recline the seat as far as possible.
Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions).
On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the ****** belt at the bottom.
Unhook the looks from the shoulder straps from the metal clasp.
Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to wash.
Thank you.
2answers
Hi, I would like to know if the front seat belt retractors for Honda CRV 2003 are the same? If yes, is it difficult to replace the seat belt assembly? I'm planning to buy a used front passenger side...
I don't know if this is something you want to get into? You decide. Front Seat Belt Replacement SRS components are located in this area. Review the SRS component locations and the precautions and procedures before performing repairs or service.
NOTE: Check the front seat belts for damage, and replace them if necessary.
Front Seat Belt
  1. Make sure you have the anti-theft code for the radio, and then write down the frequencies for the preset buttons.
  2. Disconnect the negative cable from the battery, and wait at least 3 minutes before beginning work.
  3. Slide the front seat forward fully.
  1. Pull the lower anchor cover (A) back, and remove the lower anchor bolt (B).
  2. Remove the B-pillar lower trim panel.
  1. Remove the upper anchor cover (A), and remove the upper anchor bolt (B).
  1. Disconnect the seat belt tensioner connector (A), and detach the harness clip (B) from the retractor (C). Remove the upper retractor mounting bolt (D), and the lower retractor bolt (E), then remove the front seat belt (F) and retractor.
  2. If necessary, remove the front seat belt protector (G).
  3. Remove the B-pillar upper trim.
  1. Remove the shoulder anchor adjuster (A).
  1. Install the seat belt in the reverse order of removal, and note these items:
    • Assemble the washers, collar, and bushing on the upper and lower anchor bolts as shown.
    • Check that the retractor locking mechanism functions.
    • Apply liquid thread lock to the anchor bolts before reinstallation.
    • If the seat belt tensioner has been activated, replace the front seat belt protector with a new one.
    • Before installing the anchor bolts, make sure there are no twists or kinks in the seat belt.
    • Make sure the seat belt tensioner connector is plugged in properly.
    • Reconnect the negative cable to the battery.
    • Enter the anti-theft code for the radio, and then enter the customer's radio station presets.
    • Reset the clock.
    • Do the PCM idle learn procedure and the power window control unit reset procedure.
Upper anchor bolt installation
Lower anchor bolt installation
Seat Belt Buckle
  3. Remove the front seat.
  4. If equipped, remove the center table.
  5. Remove the under seat storage box.
  6. Remove the center cover, driver's, passenger's.
  1. Driver's: If equipped with seat heater, remove the harness band (A), and disconnect the seat subharness connector (B). If equipped without seat heater, detach the seat belt switch connector clip (C). Detach the seat belt buckle tensioner clip (D), and harness clip (E).
The automated shoulder strap part of the driver side seat belt will not move to position over the shoulder
pull the strap out till it stops it probably just has a twist in it tightening the retractor
1helpful
91 honda ex, passenger front seat belt is not working and the light in the dash board keeps lit, I have check the fuses for it, and all the connection to the belt and it seems all intact...any advise?
Your 1991 model Accord has automatic front retracting shoulder belts and, more than likely, the power retractor motor has gone bad on the passenger side front. If the shoulder seat belt is not in the retracted position, up close against the seat, when the car is running, the seat belt light will stay lit on your dash. Have the seat belt motor inspected and replaced if necessary.
1helpful
2answers
1990 CAMRY - Automatic shoulder belt doesn't operate
right thinking, check the fuse then the relay.that's what it is most of the time.
How do we fix front passenger side seat belt retractor on 1999 Ford Taurus? It will not pull out....
you may have to remove the bolt that holds the buckle to the floor. Try to push the belt into the retractor and see if it frees up.
I assume you are saying it is in the locked mode. It has an automatic lock mode for holding a child seat. When the belt is pulled all the way out, it goes into locking mode. You will hear it ratchet when the belt starts going back in.
Section 01-20A: Restraints, Active 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Safety Belt, Lap/Shoulder The dual locking mode retractor on the shoulder belt portion of the combination lap/shoulder safety belt for the front seat passenger and rear seat outboard passengers operates in two ways:
  1. In the vehicle sensitive (emergency locking) mode, the shoulder belt retractor will allow the occupant freedom of movement, locking tight only on hard braking, hard cornering or impacts of approximately 8 km/h (5 mph) or more. The front and rear outboard seat belt retractors can also be made to lock by pulling/jerking on the belt.
  1. In the automatic locking mode, the shoulder belt retractor will be automatically locked and remain locked when the combination lap/shoulder safety belt is buckled and does not allow the occupant freedom of movement. This mode provides tight lap/shoulder belt fit on the occupant and on a child safety seat or infant carrier installation restraint.
  1. When the combination lap/shoulder belt is unbuckled and allowed to retract completely, the retractor will switch to the vehicle sensitive (emergency) locking mode.
sxh~us~en~file=ani_caut.gif~gen~ref.gif WARNING: REAR-FACING INFANT SEATS SHOULD NEVER BE PLACED IN THE FRONT SEATS.
The automatic locking mode must be used when installing a child safety seat on the front passenger seat and rear outboard seats where dual locking retractors are provided
Problem with 1994 Escort Seat belts
Just bought a 95 escort same problem on passenger side. Mine was the door latch, it's covered with a rubber boot to make contact when shut. If the boot is wore out it makes contact all of the time causing it to stay in the shut door position. Being handy I cut a piece of plastic from a fast food place and fit it in between to break the contact when up. Belt moves as it should now.
2answers
Electric retractable seat belt problem
check your fuses. there is also a lever next to te parking brake..make sure it's down
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
