If you have checked to make sure the bed is plugged in and the outlet works, recommend contacting Craftmatic. Here is a link to download the manual. http://www.craftmaticparts.com/index.php?main_page=index&cPath=10
Troubleshooting steps are included along with the contact information.
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
check for a bad brake light fuse! if not the fuse, the brake light switch operates brake lights and if bad you will not be able to shift it out of park, as well as the brake lights not coming on.! because you have to put foot on brake to do so. if bad switch, it wont let it out of park. it could be just out of adjustment also!! good-day !
have u check the bulbs?.... i would try to see if they ok remove em an check for power going to those locations, activate ur switches an see if you get any power may just be burned bulbs..... if the fuses seem to be OK
