Washing Machines Logo
Paula Lynch Posted on Jan 31, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a new Frigidaire Laundry Centre. # ELX FFLE39C1QW wont agitate and wont spin the water out of the clothes
Bill Boyd
Level 3:
Top Expert:
  • Frigidaire Master 53,816 Answers
  • Posted on Jan 31, 2016
Bill Boyd
Frigidaire Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11946826
Points
172802
Brand new-- call for a warranty service
don't touch it yourself as it voids the warranty
Frigidaire Laundry Center (FFLE39C1QW0) agitates & slow spin
either belt loose or agitator cogs under agitator bad
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Excessive vibration and movement during spin cycle
mostly its faulty motor problem or drain problem. It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Frigidaire Front loader nightmare!
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
2answers
Washing machine shaft wont move
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
When the clothes are wet at the end of a cycle, check these:
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
2answers
Damaging clothes
How long is the gentle cycle?. I prefer to make my own delicate cycle. I let the machine fill, agitate about 1 min. then turn off and let soak about 15 - 20 min. Make the machine pump out and start spin very briefly. stop machine. let fill up again and repeat to rinse. Don't let agitate for more than 3 or 4 min total wash and rinse don't let spin completely.
2helpful
2answers
Washer repair
The transmission might have locked up causing the motor to overheat.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
