Showing misfed paper @ U1 U2, paper jam out, but still showing misfed.Checked and all paper is out. How can this be reset? Thanks
  • 183 Answers
In the machine can be a little fragment from a sheet of paper so watch careful it can be right on the sensor for registration please open all doors and close them again.
But for i to be able to help you more you will need to tell me what brand is the machine and which is the model
Posted on Jul 15, 2009
When i on my copier and pres copy, it print in blank and bring J98 after picking one paper
This is from the users manual:
"Open the drawer and left cover and check for any misfed paper. If the same indication appears, contact your service representative."
http://www.instructionsmanuals.com/u2/pdf/fotocopiadoras/Kyocera-KM1505-en.pdf
Jan 16, 2015 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
Bonjour, comment faire un reset total pour revenir a la configuration d'origine du d7000? merci
Bonjour cher ami, vous pouvez revenir aux réglages par défaut en appuyant avec un point vert ("Qual-+/-") simultanément pendant quelques secondes.
Pour réinitialiser les paramètres personnalisés que d'autres: se déplacer U1 ou U2 le commutateur de mode U1 ou U2, appuyez sur Menu et vérifier U1 ou U2 Ok sélectionnez Restaurer, cliquez sur OK.
Regards
Mar 13, 2011 | Nikon D7000 Digital Camera
IF I HAVE A MOTOR WITH STAR DELTA WINDING AND NO LABELING IS DONE HOW WILL I CONNECT THE CABLES TO THE MOTOR
the motor will have 3 pairs that can be checked with a ohm meter for continuity. each pair has a start and a finish. usually it would be labelled U1 V1 & W1 for the start and U2 V2 & W2 for the end or finish.
To connect in star ( Motors that start with direct load ) supply cables to U1 ( Red ) V1 ( White ) W1 ( blue ) and bridge out U2 V2 & W2.
To connect in delta Supply cables as above. Bridge U2 to V1 - Bridge V2 to W1 - Bridge W2 to U1.
If you have a reversed winding the motor will growl and not turn.
To reverse direction of rotation swap any 2 supply cables ( But only when the power is OFF )
Mar 09, 2011 | Kitchen Ranges
I had a paper jam.I cleared the jam. the misfed light is still blinking. doese this model have areset botton?
There is no reset button or switch. The reset is performed by opening and closing the right side door. Make sure there is not a sheet of paper just starting out of the tray. Also check the fuser gate. Sometimes these break. The rear side of the gate has a small tab that blocks a sensor. If the gate is out of position it will show a jam all the time. Just make sure the rear side tab is "in" the sensor housing. The gate looks like this:
afa6551.jpg In this picture the "sensor" tab is at the far end of the picture.
Good Luck and Thank You for using Fixya.
Jun 09, 2010 | Sharp AL-1641CS All-In-One Laser Printer
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Display says "Remove misfed Paper info. code =184
Hi Alara,
Check that the printer is actually trying to pick up the paper. The printer tries to pick up paper but couldn't. It thinks there is something preventing the paper from getting into the input paper registration detector.
Rgds
S88
Dec 18, 2008 | Panasonic Office Equipment & Supplies
Misfeed error
1. Check that absolutely no paper is jammed within the infeed paper sensors. Sometimes a tiny piece of paper will get stuck in the sensor after a jammed sheet has been forcibly removed.
2. Use a can of Dust-Off or similar compressed air product to blow the paper path out. Paper lint can block a sensor.
Feb 23, 2008 | Ricoh 6513 Copier
Paper Jam
hi im jules_09.have you reassemble the fuser correctly?check again the inside of the machine for small pieces of paper its just there the machine wont flash the misfed if there is nothing stock in the machine.although sometimes the drum can cause the misfed,try to full out the drum.it cant be stock just see if the drum is rotating try to rotate it 360 then slowly full it out,also check if there are srews where the drum process unit is at
Oct 12, 2007 | Toshiba E-STUDIO 650 Copier
88 people viewed this question
jasbo
jasbo
