Question about LG LMV1630 Convection/Microwave Oven
Microwave matsui M183BT. There is an L in the top left hand corner of the display screen and an error message appears when I try to use the microwave. Can you advise me?
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
Jun 14, 2012 | Samsung SMH8165W Microwave Oven
F3 Message on microwave
Hello
GE microwaves with a digital display will show an error code when there is a problem or malfunction with the unit. One type of error code that will be displayed on a GE oven and require troubleshooting is a code F3. An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
Repeat Step 5 for the other membrane that is on the control board.
Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
Peel the wax backing off of the top membrane, then place it on the control board.
Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
Plug the microwave back into the power outlet and reset the clock.
Oct 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Gold Accubake system microwave indicates door open whenever try to heat. Light (inside microwave) does not come on when door is open. Door open error stays on until cancel button clicked then...
I just had the same problem with my microwave. First DISCONNECT THE POWER. Remove the front top grill (screws are on top of microwave). Unscrew the one screw at the top of the control panel and lift it out of the way. You will see three micro switches to the left of the pannel. I bent the metal frame they were mounted to by hand to move them back into place. The microwave oven works great now. If this does not help, then I would consider replacing the top limit switch.
Jul 13, 2010 | Microwave Ovens
It displays SE and nothing works.
SE error means you have a shorted membrane keypad.
With your model number I can detail your options.
Jul 02, 2010 | Samsung SMH7178STD Microwave Oven
Microwave won't heat, error message comes out"error sensor"
The moisture sensor has failed.
The part is located on the top of the unit in back left corner. To get to it you will have to take the microwave oven down and disassemble it, There are about 8 screws on the bottom, 9 on the back and 4 on top that have to come off and then the wrapper will come off. The sensor is the round metal disk with wires attached inside a metal cable that run over to the control. The part runs about $125.00
May 12, 2010 | Frigidaire PLMV169DC Microwave Oven
Bottons on microwave do not work
HI, the touch pad board has failed. you will need to replace this damaged board asap. this will correct the issue.
Sep 27, 2009 | Microwave Ovens
Nu-tec NTV2131 51cm TV
Press the 'display' button for 5 seconds
Mar 31, 2008 | Hotpoint RVM1625 Microwave Oven
LG LMV1630 Convection/Microwave Oven Logo
73 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
