How do I connect my phone to my tv? It keeps saying theres no signal? Could this have something to do with the tv not being mhl compatible? Is there a way around that?
1st and foremost You can Only Connect a (MHL Enabled Device) to an HDMI TV . I Do Not know from the given information if Your Tablet is MHL Enabled ??? Here is a link to check your device Compatibility http://www.mhltech.org/devices.aspx . If it is Enabled are the services for MHL Devices started and running on Your Tablet Here is a video link for setting up MHL devices https://www.youtube.com/watch?v=GrBkQ4GUXf0&hd=1
Dec 18, 2012 - 25 posts - ‎22 authors
The specs are below. ... I just got my irulu 4.2 Jellybean tablet and this is my first time dealing with anything other than desktop and non smart phone. ..... There is a hidden phone on the irulu X7 called dragonphone and I have ...
Now mirror your smartphone or tablet featuring MHL technology on a display or projector. Please ensure your device is MHL enabled by visiting the link below. •
Oct 14, 2013 - That means you must connect your MHL smartphone or tablet ... flash drive and plugs directly into an MHL-compatible HDMI port on your TV or ...
HaierSimple one cable connection for high definition audio and video. MHL enabled. Mobile High Definition Link allows you to connect compatible devices, such as ...
+/- . In the MENUscreen, these buttons serve as up/down buttons. 5 POWER. Press to turn on and ... Connect cable pr antenna signal to the TV, either directly or ...
Look up your Vizio model and see it it supports something called DLNA or Miracast. If it does you go to into your phone settings and turn on WiFi and Nearby Devices (DLNA). On your tv go into the settings and look for anything that says DLNA or Miracast and turn it on. Have it search or scan for compatible devices. If it finds you phone it will connect. Your phone will confirm that a connection has been established and then you can simply start playing your music from your phone.
A much simpler method is to buy an MHL cable from Amazon. MHL converts that small connection on your phone to an HDMI connection for your tv. Not only will you be able to stream music but you can show video, as well. The cables are cheap. Just search for MHL on Amazon. Good luck!
Check to see if your specific Androind phone supports MHL. Simple Google search should answer that. If it is, check the connection to your phone, the cable, and the TV. If you plug it into HDMI 1 be sure to set your input to HDMI 1. Hopefully this info helps.
How to connect Samsung Galaxy S3 to TV..
There are 3 ways to do this..
1. You can use a compatible MHL adapter that connects to the micro USB charging port of your phone and then a regular HDMI cable from your TV connects to the MHL adapter that's connected to your phone. You will have to connect the Samsung micro USB charging cable to the MHL adapter in order for this to work.
You will be able to see everything that you do on your device, however you will be limited to how you hold your phone if you are trying to play a game and direct what you see on the screen to the TV.
Note: the MHL adapter may overheat your device if you have it on and working for long periods of time.
2. You can use a remote access app on the phone to view on a PC/TV monitor. Depending on the remote access app, there maybe a lag seeing the image on your screen. Most apps like this are paid apps.
3. The Samsung Galaxy S3 phone has a natively installed software tool on the phone or can be downloaded from the Samsung Galaxy App Store (Available after you set up your Samsung account on your phone) that can link to a compatible DLNA device (most TV's that are 2005 or older). The app is called Samsung AllShare Play, or it may also be called Samsung Link
