Question about Compaq Presario 5000 PC Desktop
No operating system
I bought my computer from tecomputers so the operating system was wiped, I got a version of windows xp because I was told it was compatible. when the windows xp setup is finished and the computer restarts it does the windows xp setup again it keeps doing it again and again. well thanks you hope to hear some good news back.
  • 328 Answers
Should be one of two things.
First: Make sure you remove the disk as Windows restarts as it may be on a continuous cycle even after Windows is done loading.
Second: You should check your hard disk for errors and have it repair any bad sectors. This is done by: Booting from XP and choose the Recovery console Once your in DOS (black screen
with a flashing cursor) type in the following commands exactly
" chkdsk /r "(this will check you hard disk for errors, it will take a
while depending on size of your hard disk). Then continue any additional disk repair options. If this all fails then the problem is with a bad hard drive and has to be replaced.
Posted on Nov 18, 2007
The times bridge program will not install on vista bought as a present
Installing the programs made for another version of Windows may cause problems. Vista may have a right click option to install as XP.
Jan 16, 2013 | Computers & Internet
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
How can i fix my windows if is not genuine
That means your operating system is not a genuine version which u not bought
try to buy an operating system legally...and this should end your problem
"be free to ask about further more doubts.... am here to help u based on computers:-)"
Jul 19, 2011 | Dell Inspiron E1505 Notebook
Cd kit 394378-002
The windows XP operating system has several versions. Computers with the default windows XP operation system only requires updates to the versions of SP 1 or SP2 that are improved versions over the default to achieve experinces. The windows XP operating system version SP1 and SP2 are installable with the first default version beign present on the computer. Also, computers that are least windows XP compartible are incapble of crossovers to SP1 or SP2. Windows XP default on the computer makes possible system conversions however. Windows XP operating systems computers allows to acquire from software retails to replace malfunctions. Ascertain the computers compartibilities and with the version of the default system as referece to acquire the most appropaite operating system at retail.
Feb 05, 2011 | Microsoft Windows XP Professional SP2
I need to do a windows repair but I cannot find my cd. Can I download one and save it to a disk and install it on a different computer
Ask your friends to borrow either a "retail" Windows XP Home Edition CD-ROM (bought when XP was available in retail stores) or an "OEM" (Original Equipment Manufacturer) version. The OEM version was used by Microsoft-licensed "system-builders" (small computer-stores that assemble computers from the individual components, and then install this "generic" version of Windows).
If you have the "genuine Windows" decal on the side of your desktop, use that 25-character product-key and the "borrowed" CD-ROM to reinstall Windows.
Nov 18, 2010 | Dell Microsoft Windows XP Home Edition
My problem is to remove the genuine software from my computer because no backrounds are showing in my desktop
The "Windows Genuine Advantage" software on your computer has discovered that you are using a "counterfeit" version of Windows XP.<br /> <br /> So, if you bought the computer from a computer-store, and they installed Windows, you can report them to Microsoft: call 1-800-R-U-LEGIT to report them as "software pirates".<br /> <br /> Or, see: <a href=""></a><br /> for information on how to convert your copy into a "genuine" copy of Microsoft Windows.<br /> <br /> Or, buy a retail copy of "Windows 7 Upgrade", and upgrade your Operating System from XP to the latest version.<br /> <br />
Aug 25, 2010 | Microsoft Windows XP Professional for PC
Hello, I have a packard bell i media 5076 and have had to wipe the hard drive because of a virus. Unfortunately I have lost the master disk and bought a copy of Windows xp which turns out to be a fake. I...
You cannot fully recover the data on your hard drive anymore, you can create a recovery disk again after your manual installation of your copy of windows, want help about your drivers? pm me i will assist you
Oct 21, 2009 | Computers & Internet
Installing Windows XP alongside Vista
First you want to install xp and then only you want install vista because higher version will not take lower version.
Feb 26, 2008 | Microsoft Windows XP Professional for PC
No operating system
start ur computer
hit delete to enter setup
go to the second title of the setup ( i forgot wats called heh..)
go to first boot device and choose cd rom
exit saving changes and restart ur pc
u will see the phrase ( hit any key to boot from cd)
hit any key and start the installation.
ps: try to get windows xp sp2 ...its good
Nov 13, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
