Question about Archos 604 WiFi Digital Media Player
My archos 604 won't play on my television.
I have connected it to the DVR station and put in the wires as shown but it won't play on the television. The picture shows on the archos but no sound and the television just shows normal tele. What am i doing wrong Please help. x
  • 577 Answers
Hi,when you connect it to TV,I believe you switch to AV mode on TV to allow signal to be shown on TV,do you ??.
If you did it but no video ,than make sure your AV cable should go all the way down on the plug on Archos.it is a fancy plug sometimes stays out half way
kazim
Posted on Sep 26, 2009
Can I charge archos 604 batteries using dvr station and power outlet?
yes you can, however the battery must be inserted into the 604. Simply dock the 604, ensure the dvr is turned on and the 604 will automatically turn on and start charging.
Sep 09, 2010 | Archos 604 Digital Media Player
I need a manual to operate the remote control for the Archos DVR Station for 604, 504& 404. Thank you.
user manual:
http://www.archos.com/support/download/manuals/user_manual_dvr_station_imt_v1.pdf
connection sheet (USA):
http://www.archos.com/support/download/manuals/connection_guide_usa_dvr_station_imt_v1.pdf
connection sheet (Europe):
http://www.archos.com/support/download/manuals/connection_guide_euro_dvr_station_imt_v1.pdf
Aug 18, 2010 | Archos DVR Station MP3 Player
Lines across tv when using archos with dvr station, fine when not using on tv
SOunds like a problem with the connection between the dvr station and the tv. Ensure all connections are insered fully and dust free. Also ensure that you have set the output signal to PAL if using in Europe - do this via the setup menu
Aug 08, 2010 | Archos 604 Digital Media Player
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Apr 09, 2010 | Archos 604 Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Same here david! ARCHOS DVR STATION GEN 5 REMOTE NOT WORKING
Hi g tongsonmy name is Mike Houston of DISH Network and I was going over your post and seenwhere your Archos DVR is not working with the remote. If your Archos is sync tothe DISH Network receiver and all the functions still are not working you willneed to call Archos and I will give you the number. Archos (Pocket Dish),8773008879
Jun 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Dvr docking station
I had the problem that the record feature was not available in or out of the docking station and therefore i could not record. Archos connector on bottom of unit senses a change in the resistance of the device it's docked with and knows if it's the DVR station or not.
Turned out to be a hardware fault - i had to RMA both the Archos and the docking station (while in warranty) and Archos fixed it/them.
That may not help you much.
PS: I think i zapped my DVR station with static one day and that might have been the original cause.
Dec 31, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Archos 604 dvr blank screen
It sounds to me like there's an Component A/V cable issue. Please re-check the cable connections making sure they are connected correctly. When using the docking station and Component A/V cables you must be sure the cables are connected with their corresponding colors on the back of the DVR Docking Station. Also check that the format of the recording is compatible with the "TV Standard" in the settings menu of your Archos. It will be either NTSC (USA) or PAL (Europe). Be sure to check the Video Output Settings of the Archos to be sure it is set to the same type of cables you are using- component, RGB, s-video or composite. Good luck!
Sep 13, 2007 | Archos 604 Digital Media Player
Archos 604 WiFi Digital Media Player Logo
281 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
