Question about Kenmore 44042 Front Load Washer
Overloaded washer and won't drain
My daughter overloaded the washer and now it won't drain. We took out all of the clothes and ran it several times, but water is still sitting at the bottom of the tub.
  • 92 Answers
Hi,sounds like you have a blocked pump,
Posted on Jul 15, 2009
Kenmore washer 417.440082400 showes a E41 code. Whats wrong?
Posted on Oct 09, 2009
Yeah x my Maytag model number mvwb450wq keeps giving me an overload code if there's not any clothes in there and it drains i
I believe yours is an upright model am I correct? some of these models had suspension and a sensor and they determined that the suspension was too weak therefore the suspension has to be changed. its for rods that mount from top to bottom that the drum sets in let me do some double checking. Okay here's the instructions that should get you going.
Is the washer overloaded? The washer has attempted to ?ll and begin a wash cycle. If the washer is overloaded, it will drain any water and detergent that was added during the ?ll. To correct the overload, remove several items and add detergent. Close lid and press START.
That's how it should be perfect world where washing machines are constructed with quality materials. However, in this wasteful world of poor quality the inner tub may be jammed in the down position, unable to float off the drive hub because of a rusted drive shaft! Or hopefully there is just a sock or something lodged in between the inner and outer baskets causing the same result.
Let me know if that works
Nov 30, 2015 | Maytag Washing Machines
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
Dl and F flash when I'm trying to start the cycle...
sorry for the delay in getting back to you. you have a bad door latch mechanism on your washer that needs to be replaced.
Dec 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
Yeah I have a small whirpool washing machine. I stuffed it with too many clothes & it overloaded therefore causing it to smoke... So I unplugged it before it had a chance to really heat up! So the next...
Overloading the machine puts extra strain on the motor and the smoke you saw was most likely coming from the motor. As you unplugged it and it ran normally the next time, you may have avoided doing any damage - or at least serious damage - to the motor.
You should be able to continue using the machine with no problem, but don't be too surprised if your motor quits in future. If you are using the machine again and you notice smoke - whether you've overloaded the machine or not - switch it off and have it replaced or at least inspected.
Regards,
BElectric.
Dec 06, 2010 | Amana NAV8800E Top Load Washer
Not lit up to show power
You may have overloaded your washer. Some washers have a safety trip feature that activates when the motor is overloaded. Try unplugging the washer and removing the clothes. Once you have done this, go ahead and start the washer again. If you that doesn't work, you made need to check if you have blown an internal fuse or call a qualified technician. I hope this helps. Good luck.
Jul 23, 2010 | Fisher Paykel EcoSmart GWL15
Washer is smoking....
SOUNDS LIKE SHE SPUN THE BELT UNPLUG ELECTRIC , EMPTY WASHER, TIP BACKWARD CHECK UNDERNEATH BELT, IDLER, PULLY AND BRAKE PADS . SEE IF DAMAGED MAY NEW NEW BELT
Feb 04, 2010 | Speed Queen Washing Machines
I think a overloaded the washer and it wouldnt spin.
Frigidaire washer will not take a overloaded tub without causing belt problems.
Unplug the washer.
Remove the 2 screws on the very bottom of the front washer panel.
Slide the front panel down slightly and remove it from the cabinet.
Inspect the belt around the motor pulley and transmission.
If it is worn at all it needs replacing.
You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
Keep your hands,fingers and tools away from all moving parts.
Jan 24, 2010 | Frigidaire FGX831F Top Load Stacked Washer...
Kenmore 44042 Front Load Washer Logo
345 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
