Question about Sony VAIO® VGC-RC310G PC Desktop
My sony Vaio vgc-rc310g wont restore from the rescue disks any longer. The display is garbled--wrong characters and different colors. what may have happened: the monitors were flashing off and I received an nv4 display error--I went to this website and followed the instructions and then the display went to vga I think--http://www.christopherjason.com/articles/nvidia-nv4disp-problem/
  • 5 more comments
  • kamiblue Jul 15, 2009
    Hi ****,
    I can read the screen while using the recovery disks--its pixelated etc but the characters are displaying correctly--after it finishes the characters are garbled and then a message comes up that it wasn't fully restored so I am unable to enter Safe Mode. Would this still mean a bad video card or is the BIOS corrupted? Also, I have a CMS Velocity back drive and recently made a full backup of the system. Unfortunately, when I swapped the drive into the Vaio it informed me that it was that certain window files were either missing or
    corrupt:
    \WINDOWS\SYSTEM32\CONFIG\SYSTEM
    See article:
    http://support.microsoft.com/kb/307545
    Unfortunately, I dont have windows 2005 mce on disk --
    What do you suggest? Should I try installing a new video card and if so what cards would be compatible?--I believe it has an Nvdia geforce 7600 gt but dont know if thats available anymore and would like to upgrade if possible. Also, should I buy windows 2005 mce on disk and use the CMS drive as my primary drive in the system?
    Cost-wise? do you think its worth it to try and fix this system or should I just purchase a new desktop?
    Thanks,
    Pat
    Hi ****,
    I can read the screen while using the recovery disks--its pixelated etc but the characters are displaying correctly--after it finishes the characters are garbled and then a message comes up that it wasn't fully restored so I am unable to enter Safe Mode. Would this indicate a bad video card or something else, say a corrupt BIOS? Also, I have a CMS Velocity back drive and recently made a full backup of the system. Unfortunately, when I swapped the drive into the Vaio it informed me that it was that certain window files were either missing or corrupt:
    See article:
    Thanks,
    Pat
    Hi ****,
    I can read the screen while using the recovery disks--its pixelated etc but the characters are displaying correctly--after it finishes the characters are garbled and then a message comes up that it wasn't fully restored so I am unable to enter Safe Mode. Would this indicate a bad video card or is it something else, possibly a corrupt BIOS? Also, I have a CMS Velocity back drive and recently made a full backup of the system. Unfortunately, when I swapped the drive into the Vaio it informed me that it was that certain window files were either missing or corrupt:
    See article:
    Thanks,
    Pat
    Hi ****,I dont have the OS on disk---the backup I made is a full image backup--the CMS Velocity backup system is supposed to allow for a clean swap---Unfortunately, because that windows file is corrupted it wont work--I contacted them and they said that having the the OS on disk may allow for the image to be restored...ok, so let's say the video card is bad---What can I replace it with? I dont believe that card is available any longer and Id like to upgrade if possible anyhow---Thanks,Pat
    Thanks ****,
    any suggestions? Im concerned about the PSU needing to be upgraded too--What card would you recommend?
    Thanks again,
    Pat
    One other question--do you think replacing the video card would allow the rescue disks to restore the drive or are there additional problems?
    thanks,
    Pat
    yes--I think it definitely pointed me as to what to do next
    President:
  • 948 Answers
If you can no longer read your screen when booting to your rescue disks then your video card is bad and must be replaced.
If you can boot into Windows Safe Mode and read your screen your video card is NOT bad, but you should remove your video card drivers in safe mode. Windows will then revert to VGA mode. You can use your rescue disks to reinstall the video drivers, but better would be go to Sony's website and download the latest drivers and install them. You can put them on a USB stick and tell Windows where to find them while reinstalling.
Posted on Jul 15, 2009
  • 2 more comments
  • Dick
    Dick Jul 15, 2009
    If it is pixelated that is a good indicator that the card is bad. If you are electronically inclined you might pull the card out and look for bad capacitors.
    Are you able to dispense with using any Sony recovery disks and simply use the Windows disk instead?
    Making a backup of your system does not mean that you can then install that drive into the system and start running. It means that if you have a hard drive crash, all of your data is safe on your back up. The backup does not have an operating system on it unless you did something really non-standard like created an image of your drive on the backup.
    But let's limit our discussion to the issue at hand and get your computer going again. If you can boot using the Windows CD go to the recovery console and run chksdk. This will check your hard disk for physical errors. Report back with your results. When you reboot, press the F8 key repeatedly just after the POST screen, see if you can get to the Windows boot menu that way. If you can, choose Safe Mode. Let me know what happens from there.
  • Dick
    Dick Jul 15, 2009
    Your Vaio video card slot is a PCI-E 16x slot. You can get any card that will fit in that slot and you'll be fine. Newegg or Tiger Direct is where I shop online. You can get them anywhere though, that is a very common interface. You are not obligated to use another Nvidia card, you can use any manufacturer.
    Good luck.
  • Dick
    Dick Jul 15, 2009
    Any one of the cards here would work. The MSI one for $49 with the native HDMI port looks like a good one. Biostar & Asus both make good motherboards, never used their video cards yet. Also since you mentioned power supply Newegg has a "shellshocker" special deal daily, today's is a 400w power supply.
  • Dick
    Dick Jul 15, 2009
    "do you think replacing the video card would allow the rescue disks to restore the drive or are there additional problems?"
    I'm not sure exactly what is on those rescue disks so I can't answer for sure. My guess would be no. I would try to borrow an Windows XP Media Center install disk and reinstall my operating system if I were you. Once you have it installed you should be able to restore your files from your backup.
    If you really want to think outside the box and have a spare hard drive around, see if you can "restore" by using your recovery disks to put an OS on the new drive. I have no idea what is on those disks, it could be the entire OS, drivers and all.
Sony vgc rc310g will not see a 1.5 tb drive
Format it with EASEUS Partition Manager. It's totally FREE and an awesome Program for formatting and manipulating hard drives. It's very easy to use.
You can get it here: www.partition-tool.com/
Aug 18, 2012 | Sony VAIO® VGC-RC310G PC Desktop
I have a sony vaio VGC desk top - it is probably 6 years old or so. I went to start it th other day and it sounds like its firing up and you can hear the fan working - then a constant beep noise starts...
The constant beep signifies that one or more RAM has(ve) been dislocated from the RAM socket(s). Try to re-assemble the RAM(s) into the proper position(s) and re-start your computer. I hope this will work the best for you.
Dec 29, 2010 | Sony VAIO® VGC-RC310G PC Desktop
Sony vio is beeping not starting
Maybe you need to replace the memory. If you don't know how I suggest to take the computer to a repair shop.
Dec 20, 2010 | Sony VAIO® VGC-RC310G PC Desktop
My VGC-RC310G won't read SD cards in the slot. I have tried reloading the origional drivers, registry fixes, etc... This has been an onoing problem and nothing is working. Please let me know if there is...
Have you tried different SD cards and card readers?
Back up your registries and perform a system restore.
Run malware bytes and run a complete scan on your computer if possible try this in safe mode with networking.(restart the computer ant start tapping F8 key and select safe mode with networking)
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Sony vgc-rc310g sound card not work with Windows 7
pleases download and install the latest audio driver from sony's website
Feb 14, 2010 | Sony VAIO® VGC-RC310G PC Desktop
I turned on the computer to allow it to download
not as far as im aware try removing the 24pin connector from mobo and replacing it then reset the bios jumper by jumping it from norm to reset then turn on pc for a second turn pc off and jump it back power up pc and this should fix issue
Jan 01, 2010 | Sony VAIO® VGC-RC310G PC Desktop
I cannot boot my vgc-rc310g after removing trogan horse (2ea)
Your laptop still has a virus. From your description, you seem computer savy. What u need to do is you need to boot your system with UBCD ( can be downloaded at www.UBCD4win.com) and search for files with the extension as .exe and delete the ones that look like folders.
then you reboot and try and log into your system. Next, download a software called Combofix. You google it out and get a download. run that to remove the remaining viruses and fix your regsitry.
Feb 22, 2009 | Sony VAIO® VGC-RC310G PC Desktop
Sony Vaio VGC-RC024 will not boot up
Try when system is booting up, press F8 to come into boot choices.
Select last known good configuration.
select OS
if it still hangs try F8 again on boot and go into safe mode,
If neither way works the master boot record may be corrupt or viruses may be preventing boot up.
Mar 31, 2008 | Sony VAIO® VGC-RC310G PC Desktop
Sony VAIO® VGC-RC310G PC Desktop Logo
205 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
