Question about Nikon COOLPIX L18 Digital Camera
My lens is stuck-will not close. The screen displays "lens error" message. how can i fix the problem?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Posted on Jul 18, 2012
advance
  • 107 Answers
SOURCE: Lens error
The most common cause of this issue on the L3 is an impact which dislodges the focus element in the very front of the lens. The metal platform that the focus system is mounted to is attached with 1 screw and is able to flex slightly under stress. When impacted it flexes and allows the focus drive to become misaligned. The lens still technically works but the camera senses that the focus is jammed and leaves the lens extended so no components will be damaged by retracting. This repair costs $145 at my shop, not an economical repair for this camera. Some parts of the focus element are accessable from the front of the lens. You can remove the metal cover (it is glued down). Generally you will not be able to re-install the lens barrier, but it can be removed without harm to the camera. When you remove the plastic plate which carries the lens barrier you will see a small metal gear, this is the base of the focus drive.
Posted on Jun 16, 2007
SOURCE: Lens Error.
nikon coolpix 4 lens error help!
Posted on Apr 02, 2008
dlundmark
  • 797 Answers
SOURCE: camera lens will not close
Hi:
Sometimes you can try to get it unstuck by looking at the lens at is is. Then determine if it appears to be at a slight angle, if so, it may be that you can force the lens in the opposite direction. This may not work, and may damage the lens further, however, since it is not working, trying may be just what is needed.
I have had some success by forcing the lens in the opposite direction as it is turned on with pressure of my fingers pushing it. It has not always worked, but I have two which worked just fine... one was a 7.1mpxl nikon and the other was a 8mpxl Canon.
They both were off track, and jumped back by a little force.
If the lens was hit or dropped, then damage can be more than can be fixed. What can happen is that the small track parts can be broken, then there is no way to get it back on track.
Also, dirt or sand can do a number on these small parts. It is amazing how these extremely small pieces of sand can jam a lens, but I have seen it happen.
Take a hint and keep the camera away from sand and water, or risk trouble.
Posted on Jun 21, 2008
tatiya123
  • 14 Answers
SOURCE: My Nikon Coolpix S5 has
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Posted on Mar 23, 2009
  • 102366 Answers
SOURCE: lens stuck and screen saying lens eror
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Posted on Dec 31, 2009
The camera screen stays black, and I can not see anything through viewfinder or on the screen. When I take pictures, they are completely black. Is the camera worthless now?
It sounds like the CCD has gone bad, in which case, the camera is not getting repaired, since it sits on the main circuit board, and you would have to buy the entire board, plus pay the extensive labor. There may be a chance that the shutter is stuck closed, and you might try some suggestions I ran across on a web blog. The blog deals with error messages and lens assembly problems, so it's worth trying:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Hope this helps.
Jul 07, 2010 | Canon PowerShot S3 IS Digital Camera
Lens error message(nikon l16)
I was having a "Lens Error" with my Nikon Coolpix S10 camera and this websites' tips fixed my camera.
Good Luck!
Sep 27, 2009 | Cameras
Lens Error
Aug 04, 2009 | Nikon Cameras
Lens is stuck in the open position and when i try and turn on the camera, it makes a clicking sound and displays a LENS ERROR message
lens is stuck inthe open position and displays a lens error message and when I try turn on camera ,it makes a clicking sound
Jul 06, 2009 | Casio Exilim EX-S600 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Stuck Camera Lens
You could try the Casio Tech Support team, but if as you suspet it is a matter of dirt- there is nothing to be done except replace the camera- the cost os shippin and examining the camera etc. will come close to its replacement.
Jun 25, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Error 2 message
I have the same camera, but not the error message. My lens occasionally will get "stuck" out. I have found that removing the battery for a few minutes then re-installing it will "reset" the camera and the lens will retract when the power button is pressed. This "fix" does not always work.
A call to Vivitar only results in the suggestion that you send it in for repair.
Apr 04, 2007 | Vivitar ViviCam 8300s Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
35 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
