Question about Nokia 5800 XpressMusic Smartphone
Phone is constantly locked
Wen i turn the phone on it comes up with the key in the corner and my slide on the side of the phone wont unlock the phone for some reason. i have messages i cant read because the phone is locked!!
How do I unlock the keyboard
Wired keyboard usually do not have locks, However some wireless keyboard do. A switch is usually on the top side of the keyboard that slides back and forth.
However you may also be seeing "Caps Lock" which means the Caps lock key is engaged. Simply press the "Caps Lock" key again to unlock it. The caps lock key is located at the left side of the keyboard.
Dec 12, 2014 | Microsoft Wired Keyboard 600
How to install sim card
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position.
Jul 11, 2014 | Casio G-zone Commando
The key pad wont work wen i type any thing on the screen everything is frozen i have tried removing the battery i cant access anything when i type but it still wont work my key pad i permanently lock for...
Try to insert any password in your phone 10 times to erase all your data and make your blackberry Tour 9630 unlocked. If your keypad still won't work after blackberry unlocking process, try to reflash your blackberry phone. Once again if still have same result, it should be a hardware problem in your phone and you need to repair that on nearest local mobile phone repair shop.
Jul 18, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Wen i insert a sim it shows inactive sim a phone vicon with a red line shows in the top left corner
It may be due to network lock,
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.prounlocking.com/sony-ericsson-j105-naite/rs8wp9/
Dec 20, 2010 | Sony Ericsson Naite Cell Phone
My htc hero.i downloaded a screensaver app and ny i cant get into my phone.it says slide to unlock but wen i slide it it still wont unlock could u help me i tryeb reseting my phone an it still wont go...
If you havent done a master factory reset it may not have deleted the problem file. First you want to back up any informaton you want to save (pictures, contacts etc) then go >HOME, then >MENU then >SETTINGS then tap the >SECURITY option, then tap >FACTORY DATA RESET then finally tap >ERASE EVERYTHING. This will bring the phone back to the state when you first turned the phone on.
Dec 08, 2010 | HTC Hero Smartphone
Wont start
hello, i hope this is just a vehicle security issue! try (out of vehicle) , locking and unlocking driver door with key, get in and try to start, ........will any other lights or instruments turn on?
May 22, 2009 | 1998 Volkswagen Jetta
Unwanted hang-ups
There is a program called Slide to Unlock you can install. It gives you the iPhone like slide action to unlock your phone. It also allows you to set your buttons to no action without first sliding. After installing it, go to the settings and be sure that 'Slide to Answer' is ON, and 'S2A Answer Key' and 'S2A End Key' are both turned OFF.
You can find the software here:
S2U2 Software
Hope this helps!
Aug 28, 2008 | T-Mobile Wing™ Smartphone
SAMSUNG SLIDE SHUT/LOCK
If it's the SGH-D900i phone that you have... Go to Menu... Settings.... Phone settings... Slide Settings... in there you have to change the "Down" from 'Continue operation' to 'stop operation'... save and slide the phone shut, that should once again lock the keypad.
Jun 10, 2008 | Samsung SGH-D900 Cellular Phone
Samsung slide lock
Yes that's possible with every phone just go on settings, security phone settings on automatic key-gard(keyboard) and turn it off. But before you need to know the code for locking and unlocking like in all nokia is green button and *.Not sure for samsung.
Nokia 5800 XpressMusic Smartphone Logo
95 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
