Question about Crosman (4032)
My Crosman C11 is leaking gas out of the front of the barrel...
I just took it out of the case to show it to a friend, and as I placed a gas cylinder in the chamber, I immediately heard a hiss as the air escaped out of the pistol. Can someone please tell me why this is, and what I can do to fix it???
any help would be greatly appreciated.
The o-ring is missing, it is a little seal for the co2 by that green area
Posted on Apr 07, 2010
I have a F4 crosman air rifle and I can't find the place where the co2 goes I need help
It is a break barrel air rifle that when it is cocked the piston is pushed back drawing air into the cylinder so that when the barrel is closed the breach seal covers the transfer port squeeze the trigger piston flies forward forcing the air through the transfer port into the barrel accelerating the pellet up the barrel and towards the point of impact
It is not a co2 powered air weapon
Oct 20, 2017 | Crosman Optics
How to install crosman 795 part no. 10448
The Crosman 795 Detent part #10448 is "press fit" into the rear end of the barrel therefore you can use a flathead screw driver, place it between the plastic detent and the steel barrel and gently wiggle and pry the dentent off.
Jul 05, 2014 | Crosman Phantom .177 Caliber Break Barrel...
Crosman c11 - co2 cartridge leaks out.
This typically occurs when the o-ring seal near the needle to puncture the container is missin or damaged. Use a flash light and see if you can inspect the canister valve location to cehck the o-ring.
You may need to take the unit apart to check the parts. If you do not feel comfortable doing so then you need to send it for service or have someone that can work on it do so.
Mar 21, 2011 | Crosman (4032)
How do i load bb's into my c11 tactical
http://www.crosman.com/airguns/service/manuals/crosman-pistols
Nov 10, 2010 | Crosman (4032)
I had my Crosman 357 for about 15 years or so. I never used it at all until a couple weeks ago and it worked great for a few days and I liked it so much I bought more "clips", ammo and CO2 for it and then...
Well I recently bought a crosman like a month ago, I worked great, I also use CO2, then i started using it again, and all of a sudden all of the CO2 started seeping out of the barrel and CO2 area, cartridge after cartridge, so i said screw it and took it apart, and found the area that deals with the CO2 and tightened everything up. I couldn't put it back together, so i looked for the schematics and finally got it back together, then i tested it out and it works fine now. Good luck.
Oct 25, 2010 | Crosman Optics
Pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Feb 13, 2010 | Crosman Phantom .177 Caliber Break Barrel...
I have a crosman c11 that leaks gas
Ya your better spending the extra money on something with quality
Aug 12, 2009 | Crosman (4032)
Gun wont stay locked when i **** it bak
I had the same problem, it wouldn't click or stay c.o.c.k.e.d when I did a typical barrel break. I took apart the back end where the3 spring was. (screw and pin must be removed once you take the barrel out of the stock.) I found that it was the "Back Spring Guide" that was broken, but not completely, I turned it, put it back together and it worked for about 9 more shots. Then the same thing happened, so I know that I need a new one. Here is the Part # B18‐00‐6 here is a link to the part breakdown pdf from Crosman's site.
http://www.crosman.com/pdf/manuals/C1K77%20C1K77X%20%20EVP%20&%20PL.pdf
I just called customer service at 1-800-724‐7486 but they close at 4:30pm eastern time, I left a message.
I cannot find anywhere online to buy that specific part, so I assume that it has to come from Crosman. I'll let you know how I make out.
If anyone knows where to get Crosman parts, please let me know.
Thanks
MD
Aug 05, 2009 | Crosman ® Quest cal. Air Rifle with 4x32...
Crosman (4032) Logo
1,082 people viewed this question
Top Crosman Optics Experts
Anthony Coots
Anthony Coots
Level 1 Expert
Martin Clarke
Martin Clarke
Are you a Crosman Optic Expert? Answer questions, earn points and help others
