Question about Mitsubishi HD-6000 DTV Receiver / Video Recorder
Mitsubishi tv codes
Need tthe code to run everything on one remote mitsubishi 73"tv, comcast cable, and samsung surround sound
SOURCE: Universal Code for Mitsubishi CS-26201TV
After searching the web for hours this is the one that worked for me , if you have the same remote i have it should work for you too.
Code # 10150
Posted on Dec 21, 2008
tvtek
  • 1284 Answers
SOURCE: need to align my mitsubishi wd-73733 dlp tv
We TV technicians don't go into alignment unless absolutley needed. I would stray away from alignments period unless you understand all of the ramifications that come with them.
Posted on Jan 08, 2009
h_caines
  • 8 Answers
SOURCE: Comcast Remote Control Code
10150 worked for my mitsubishi wd65737
Posted on Jun 17, 2009
  • 16 Answers
SOURCE: Tv code
http://www.comcast.com/corporate/customers/customer_support/remotes.html go to this site for all comcast remote codes
Posted on Jun 24, 2009
  • 3 Answers
SOURCE: remote control programming code for Samsung dvd-r155
OK, here are the Samsung VCR codes, from the orig. remote manual.
Samsung . .. .. .. . 057, 022, 024, 053
HOLD Power Button when slider shows mode of component you want to control.
PRESS 3 digit code (whole still holding power)
RELEASE power button...
To see if it worked, press and release the power button.
Posted on Oct 04, 2009
What is remote code for Comcast cable universal remote?
If it is the original remote control to Comcast Cable box; there is no need set it up with a code. It might have been already set. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Sep 26, 2015 | Proscan PLDED3231A RK 32 Inch 720p 60Hz
Free subscription with code With new Sony TV
Syncing Comcast remote with Samsung Sound Bar. 1 Turn on the Audio/Other you are programming. 2 Press and release the "AUX" button on your Universal remote. 3 Press and hold the "Setup" button on your remote until the button blinks twice. 4 Type in the 5-digit code using the number buttons. Most likely code 21014 Others to try 20045 What worked with ours was 32609. We have a Samsung Crystal Surround Air Track (bought 12/2013). 5 If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
Dec 29, 2013 | Televison & Video
I need a Comcast cable remote code for LC225SSX. None of the codes work!!
Comcast cable remote has no setup codes with Sylvania brand TVs.
Nov 27, 2012 | Sylvania LC320SLX 32 in. LCD TV
Need help syncing my Comcast remote control to a Samsung Crystal Surround AirTrack sound bar. Is there a remote code for this?
Go to the following website to look up your particular Comcast remote and look through the remote codes. My guess if there is a code, it will be under audio equipment. Good luck : )
http://customer.comcast.com/Pages/HelpNFC.aspx?print=false&id=remotes
Jul 25, 2011 | Televison & Video
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
It sounds like you either have a signal issue or a bad converter box, possibly both
Apr 23, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Oct 22, 2008 | Sony DAVHDX265 System
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Need setup codes for Akai KC01-B2 to run with comcast remote
I have an Akai 42"lct & had the same problem. I bought an universal remote URC R6 at walmart for $19. I can now control the tv, u-vrerse cable, panasonic surround system & still have the aux open. You must use the "learn" method but I can control channels, volume, record, menues for all devices as well as setup, record for dvr & more. I hope this helps.........
Jan 29, 2008 | Akai CF2791 27" TV
Mitsubishi HD-6000 DTV Receiver / Video Recorder Logo
365 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
