Question about Microsoft Xbox 360 Console
Sound but no picture on my xbox 360
I have had my xbox for 2 years the problem started as it wudnt read any discs, games cd's or dvd's but all that started to work again and now i have the problem of when i booty it up to my tv i have sound of it booting up to the dashbord i can use the pad to scroll along to various things and it makes a sound as normal but i dont have a picture showing, can anybody help me with this problem?
Have you tried the simple but effective, pushing the plugs in harder? And putting the 360 on its side so the disk tray opens forward and you basicly drop a disk onto the tray? And lastly have you tried pushing all plugs and everything in harder? into the t.v and 360?
Posted on Jul 15, 2009
Xbox 360 wont read discs is it the dvd drive or laser
It could be a number of problems as to why your Xbox 360 isn't reading the discs. Try going to your Setting>Console Setting>Startup, set it to your disc and start up your 360. If that doesn't work, your Xbox cd driver could be showing signs of failing. The laser could be dirty also, so try to gently clean the laser eye with a microfiber cloth or some compressed air, trying not to damage the reader.
Mar 08, 2011 | Microsoft Xbox 360 Console
The xbox 360 will not read game discs or give me the option to play the game it only gives me the option to play a cd
Hi
By the problem you have described, i beleive you have a modded Xbox 360 used to play copied games, if yes you need to check what game are you playing.
If it is a latest game, then you would require a Wave 4 patch to play copied games on a modded Xbox 360, you can google on the web to find out the list of games that require wave 4 patch to run before you play the game on Xbox 360
What you need to do is first burn the Wave 4 patch on a Dual Layer DVD and load the game disc first and you would see "play CD" option, now take out the game disc and enter the Wave 4 patch disc you just burned and again you would see "play CD" option.
DO NOT PLAY the CD, just take it out again and re-insert your copied game CD in your Xbox 360 and you should be good to go.
Regards
KreativeGeek
http://gamingbox.wordpress.com
Feb 27, 2010 | Microsoft Xbox 360 Console
Why does my xbox say my games are dvds
Are you using copied CD's of Xbox games, Original Xbox 360 would read such copied game discs as normal DVD's and would show a message as "Play DVD"
To play such games it requires the Xbox 360 DVD drive to be flashed, which is called as a Softmod, if you do so you would be banned for playing on Xbox Live and such act is prohibited since it accounts to game piracy
Dec 25, 2009 | Microsoft Xbox 360 Console
When console starts to read disk; it says open tray
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using is causing the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1. If you have access to another Xbox 360 console, try to play the disc on the other console. Or, if the disc is a CD or a DVD, try to play the disc on another device, such as a CD player, a DVD player, or a computer that is equipped to play CDs or DVDs.
2. If you have an Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console, turn off the console, and remove the HDD and any attached MU. Then, turn on your console, and try the disc again. If this seems to resolve the problem, turn off your console, reattach the HDD and MU, and then delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight a storage device.Do not press the A button, Press the Y button to view the Device Options screen, Select Clear System Cache, and then select Yes to clear the cache.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked.
if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Please do rate my solution, Wish you Happy New Year and Happy Gaming
Regards
KreativeGeek
Games not reading
For disc-specific issues, check the disc for any visible signs of damage or dirt. Hold the disc by the edges without touching the top or bottom surfaces with your fingers. Clean the disc by using a soft cloth. Lightly wipe from the center outwards. Do not use solvents or chemicals to clean the disc.
2. Select Memory.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked also if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Dec 21, 2009 | Microsoft Xbox 360 Console
Does not read disc
use a dvd lense cleaner if that doesnt work take it to a game shop it prob the lasor.
Jul 15, 2009 | Microsoft Xbox 360 Console
Xbox says play DvD when there is a game in the Disc drive....
Hi. You need flash the firmware from the old drive to the new drive.
Jun 11, 2009 | Microsoft Xbox 360 Console
Inserted disc press play grinding sound and disc left scrapped
If your xbox box it's new I would take it back and get another one, becase you do probable have problems with your dvd drive and it will keep scratching the games. the laser on the drive doesn't work as hard when playing a music cd than when it plays a game or a dvd.
If you don't want to take it back, then play a couple dvds and if it reads then fine then you could try again. it shiudn't take more than ten second to read a game so if its taking longer just get it out.
Dec 27, 2008 | Microsoft Xbox 360 Console
Xbox does not read any disc
try the lens cleaner CD then try to replace it if the cleaning did not work
Dec 17, 2008 | Microsoft Xbox 360 Console
Error Message
Be sure to wipe clean around inside hole on 360 game disk it has info laser scribed that tells the system what game it is.It might also need a laser adjustment.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
134 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
