Justmar DVPSR210P -- SonyDVD player Logo
B
Brenda Baumgart Posted on Jan 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does it only play in black and white?
Just hooked it up, for some reason all I get is black and white picture? Do I need to buy more cables? Plus picture quality is grainy? Any clues?
Gareth Cockram
Level 3:
  • Master 661 Answers
  • Posted on Jan 30, 2016
Gareth Cockram
Master
Level 3:
Answers
661
Questions
Helped
315955
Points
1733
Sounds like you don't have the cables plugged in properly.
you either are just using a single cable for video out + 1 or 2 for audio (digital or analogue)
or three cables for component video out + 1 or 2 for audio (digital or analogue)
if you connect the video cables to the wrong ports on the TV you are not going to get a good output.
component video out should be quite good quality. so i recommend connecting that way
4answers
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Dvd is playing movies in black and white
Hi
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Kolbrun
1helpful
Dvd playing in black and white
problem is most likly in tv menu settings. display or picture and chang to color
2answers
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
2answers
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
6helpful
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
10helpful
3answers
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
VCR only records/plays in black and white
I just recently purchased an HD Samsung television and am trying to use it with an Insignia theater system, but picture images are night vision in blue and white. What's wrong with picture? My cable company is baffled, to say the least. What is wrong with this picture? If this system is incompatible to current quality HD television systems then it needs to be removed from market or modified.
Plasma
First of all, I'm not an expert but you might wanna change your cables. Bad and cheap cables are usually the reason for bad and snowy picture. Good luck!
Top Justmar Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Justmar Audio Player and Recorder Expert? Answer questions, earn points and help others
