Samsung Galaxy Android Smartphone: Stuck on Samsung Logo (booting up)
Hello.. I'm assuming that you did not try to install a ROM or update the firmware in any way.. doing so and interrupting the process or if on a bad connection with WiFi, or downloading a corrupt install file can break your phone causing problems.
For whatever reason this happened try the following instructions:
If the phone reboots fine you are done..
>> If the phone refuses to reboot, and hangs again at the Samsung Logo, then you know you have to go back into Recovery Mode and select "wipe data/factory reset" = after which you should be able to get back into your phone but it will wipe all of your data/everything clean from your phone. Your phone will be as if you just bought the phone with nothing of yours on it. You will have to setup your phone all over again.
SOURCE: when i turn on my
Good day!!!
Please try to change old battery of your cellphone or the part where your battery connected has loosen try to tighten it by using some small paper (place the small paper between the battery and the lock...
I hope it helps you...
Thank you...
SOURCE: samsung galaxy indulge stuck on samsung logo at boot up
1. Turn the power off first
2. Slide out the keyboard
3. Power on and press ad hold the 'R' Key
4. In Android system recovery use Vol keys to scroll up and down
5. Use the power key to make a selection.
If you cannot get to a recovery you will need to use ODIN to flash phone to factory state. this "should" fix anything unless phone itself is bad. Here is a ODIN guide for your phone. ODIN is official samsung flashing tools available for free from samsung. Good Luck.
http://theunlockr.com/2012/05/18/how-to-get-the-samsung-galaxy-indulge-r910-and-r915-back-to-stock/
SOURCE: I have a samsung galaxy note 10.1 & it is stuck
Will it reboot if you hold the power button in?
You must bring it to the technician, it needs reformat.
Testimonial: "Thank YOu"
