Question about Sharp 36K-S400 36" TV
Sharp 36K-S400 We recently purchased a used 36K-S400 and are having a weird problem with it. If we have the TV on any channel OTHER than channel 2, selecing a new channel or using flashback features work fine. But if we have it on channel 2 and try to go to another channel or flashback to another channel we just get a "snow" on every channel, even going back to 2. The only way we can get back to channel 2 is to go to 56 and then all channels are accessible again. Also, if we are watching any channel and then punch in 13, it goes to snow and we have to reset in order to access any channels. Anyone have any insight to this strange issue?
Check the tuner input mode it has (air, cable,hrc,irc) with new stations updating to HDTV the demodulation at the tv sometimes looses the color burst sync. I have seen this with more and more tv's with pip tuners , it resets to the default of air ( rabbit ears ) at 75ohms and the low band snow, when you go to the high band (56+) it finds the color sync and resets the vestigial sideband offset, it happens more often if the SAP or CC is also trying to aquire the proper offset. good luck.
Posted on Jan 01, 2008
TV may or may not come on, can unplug it and it will come on. It has white horizontal lines across the screen and sometimes it will only has half a screen picture. Once it clears up it will be like...
There are bad solder connections around the vertical output ic mounted to a heat sink close to the fly-back transformer, if you are handy with a soldering iron that would be the best option, if not! then you will need a TV repairman, since the set is 12 years old the money would be best spent on a new television.
May 20, 2011 | Sharp 36K-S400 36" TV
I have a new slimline DVD and a sony bravia HD tv. My PS3 worked with the basis cable and I recently purchased an HDMI cable and now it won't work on any of my 6 AV channels, including 1 of the 2 HDMI...
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
Whenever I turn on the TV it turns on in component input mode therfore forcing me to have to change the input every time I turn on the TV just to watch it! Can you please help me?
There may be an option in the menu section of the T V (may be by using the remote) that is switchable between turning on with last channel viewed, or it is set to turn on to a particular channel or input such as that component input. Hope this helps.
Apr 10, 2010 | Sharp 36K-X2000 TV
Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 29, 2008 | LG RC797T
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
Monitor goes Black
Try to use other monitor and check that there is still that problem or not. If not, the problem is from monitor otherwise, it would be from CPU.
Feb 19, 2008 | IBM 17IBMRBABLKNR
JVC C2628 model TV
It's a C-2628 JVC TV? And still works after 20 years????? Get it to the JVC museum...Maybe they will trade it for a new model!!!!
Nov 10, 2007 | JVC AV-27230 27" TV
A lot of white noise appearing on Panasonic CT-27SL13 27 using COMCAST
You maist likely have bad ground connections inside the tuner of this TV set. Good Luck
Jun 23, 2007 | Panasonic CT-27SL13 27" TV
Microtek ScanMaker S400
Check the scan with normal flat copy. If that scan is OK it is not the scanner.Have a rethink about how you are scanning If the the test scan comes up odd Come back with what software you are using to with thew scanner[Image editor etc.,] Do more tests before junking the scanner - that will be last move.
May 08, 2007 | Microtek ScanMaker s400
Sharp 36K-S400 36" TV Logo
127 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
