Problems with the Operation circuit on Technics SU-A900 MKII aplifier.
Does anyone know what the problem is with my amp? When I turn it on, the operation light no longer comes on and thus the amp doesnt come on.
I've had the same problem before on an earlier Technics amp.
Was wondering if this was a common fault?
Did your amp make a bang and then the problem started ?
Posted on Dec 15, 2007
Hi There Cushy,
The Amp needs Power.....and if the power switch is turned on and the light doesnt come on then there is no power....
Have a good look around the back of the amp and see if you can find a fuse please...
Its a small circular plastic item labelled "FUSE" with a screwdriver slot in it..
Turn the power off at the wall socket then unscrew this fuse holder, the glass / ceramic fuse will come out,,, replace it with one of the same physical size and of the same rating probably 1.5Amp.
Turn the amp back on and it should go if not then there is a major failure inside the case.....Needs a serice call Im afraid....
Cheers From YUBEUT
Posted on Nov 18, 2007
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
I need an Operator Manual for a Technics Amplifier SU-600
HI,
I have the User manual of Technics SU-600 in pdf format. If you can sent your email address the i will sent you the manual.Its not possible to sent the manual through this site as it is a pdf file.
OK
Oct 26, 2011 | Technics SUV500 2-Channel Amplifier
Technics amp SU-X999. I need an output I.C type SVI-4004
NAother option is to fix a universal amplifier kit into the set which powers from the same voltage preferrably a MOSFET drive which are very much available in the market and can be suited into the set. They will alos be very effficient but take care tto do the fixing mechanically , connecct the right power and groung with good shielding. Disconnect the old amp totally and use the power lines that come to the IC. I hope this works for you. Good day
Jul 30, 2010 | Technics Audio Players & Recorders
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
My technics su-a900 mk2 keeps blowing the internal fuse
Sorry but it sounds like a problem with the power supply unit.
Look for any 'burnt looking' resistors on the printed circuit board and that should give you a major clue!!
Nov 22, 2008 | Technics Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Erratic volume on Technics SU-X911 amplifier (Class A)
its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Aug 24, 2007 | Technics SA-DX940
347 people viewed this question
 Grubhead
Grubhead
