Question about Husqvarna 160 CC Honda OHC Engine 21 in
Husqvarna R53SV Petrol Mower wont start. I think too much oil had been put in. I drained some out bu still wont start. Is the engine flooded? how could i start it? Thanks
    President:
  • 1,129 Answers
Use starting fluid when it does finally start continue starting until all the oil is cleared out of the carburator you may need to repeatedly choke out the carb with the engine running to clear out the carb, do this by removing the air cleaner, start the mower on high speed rpm, and cover the air intake with your hand repeating this start/ choke/ stall procedure until it is cleared out it works, I just did this to a mower last week that had too much oil in it, the mower smoked quite a bit but eventually returned to normal
Posted on Jul 15, 2009
EFCO63C mower will not start after being left unused for 10 years
make sure you have spark, then check fuel filter, then fuel pump
Mar 08, 2013 | Garden
My mower started making smoke and then stop working?
SOUNDS LIKE THE OIL HAS FLODDED THE SPARK PLUG. REMOVE THE SPARK PLUG AND CLEAN IT USEING A WIRE BRUSH AND SOME BREAK PARTS CLEANER. THEN DROP SOME OF THE OIL OUT. YOU MAY HAVE PUT TOO MUCH IN THE ENGINE. THE SMOKING WAS CAUSED BY THE OIL BEEING BURNED BY THE SPARK PLUG. SOME HOW OIL GOT IN THERE. TRY CLEANING THE INSIDE OF THE SPARK PLUG OPENING WITH SOME CARB CLEANER. PUT THE SPARK PLUG BACK IN AND TRY TO START IT. REMEMBER IF THE SPARK PLUG IS FOULED UP, IT WILL RUN POORLY OR NOT AT ALL.
Jul 25, 2012 | Garden
My wife put diesel fuel in the gas tank trying to help me. I have drained all the fuel put new fuel filter on and it still will not start. I think there must be diesel in the carburetor bowl. Is it...
squirt some gas in the carb and start it up it will only run for a few secs so quickly keep squirting gas in ,but not to much as to flood it and that should burn the diesel out and shortly it should keep running
Jul 25, 2011 | Husqvarna Zero Turn Mower Z5426
Brand new Husqvarna R53SV 53cm Petrol Mower wont start. We put petrol and oil in it. Connected the spark plug put the choke to on, Pulled the starter string. Nothing happend. After trying a few times you...
Buy some starting fluid and spray some in the carb or air cleaner intake port, if the machine is flooding do not choke while using the starting fluid, make sure you do not have too much oil in the mowwer.
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Jun 12, 2009 | Craftsman Garden
What oil to petrol ratio does this engine run on?
http://www.briggsandstratton.com/maint_repair/manual_and_more/
Go here and enter the proper information, and see if they have the manual available.
Apr 18, 2009 | Husqvarna Garden
Can not start mower - petrol n oil ok - how do I get into s plugs
Fuel in the oil indicates an excessively rich condition. To correct, you will need to drain the petrol contaminated oil and replace with new. Then, take out the old spark plug and leave the spark plug hole open. Turn the engine over several timesby hand to help vent any raw gas in the cylinder. Then, install a new spark plug.
You should be able to now start your engine and make any other adjustments with it running.
Cheers!
Dr of Motors
Mar 20, 2009 | Garden
Replace belt on husqvarna R53SV
You may have oil in the air filter after turning it over,Remove air filter and try, if it starts,replace air filter. I had same problem.
Mar 02, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Husqvarna 160 CC Honda OHC Engine 21 in Logo
831 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
