Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune gas dryer MDG4000AWW not heating properly.
I have a MaytagNeptune gas dryer MDG4000AWW. The will lite and heat initially for about 15 seconds then shut off. It will start up again in about 2-3 minutes and light up for a shorter periord - maybe 10 seconds. After that I gave up watching. The end result is that it takes a long time or a couple of cycles to dry competely. I have cleaned all places I can get to including the outside house vent to clear lint. Since the gas lights what could be the issue? Thanks.
  • 6,784 Answers
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Posted on Jul 15, 2009
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My maytag neptune gas dryer will not heat up
heatman101
Sep 05, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Gaqs dryer does not dry no heat igniter comes on but only for short time. sometime burner lites but only for a few seconds
heatman101][\
Jul 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
How to light gas dryer maytag neptune
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Why my maytag Neptune gas dryer stopped heating up?
heatman101
Oct 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer will run, no heat I think the heating element is out, how do I replace it. Model MD5500
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not heat. It would initially heat but then the heat would stop.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Does not heat up
maytag neptune gas dryer runs but does not dry clothes i smell gas initially when i turn it on
May 07, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer won't heat up I have a maytag neptune
heatman101
Sep 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
What is the capacity of the maytag neptune mdg4000aw
motor 1/2 horse power,,,electrical,,120 60 hz,,15 amp breaker needed,,weight 160 lbs,,,capacity 3.2 cubic feet..about 26 pounds...onthe job
Jan 18, 2009 | Maytag Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
965 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
