Question about Plumbing
Does a 062N1285 valve replacement fit a Danfoss
Does a Phyrich 062N1285 valve replacement fit a Danfoss Tempress II?
  • 297 Answers
If it looks the same it may work,some valves may be interchangable must look the same.
Posted on Jul 24, 2009
Shower valve making banging noise pressure balanced even after changing cartrige
turn hose water off. open facet at lowest level to drain out lines. open a few faucets around the house to let air in. then close everything up. turn water back on. repressurize system by turning some faucets back on. see if it still happens. this is letting air back into any anti-water hammer devices that might be in system. sometimes they loose the air in them that makes them work. this should add air back in. good luck.
Mar 10, 2015 | Grohe Danfoss Tempress ll Tll Shower Valve...
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
Oo.comi have a 873 bob cat 2000 and it will move forward and back but the arms wont go up and down i do have up and down tilt on the bucket
Does foot pedal move? If not could be slide lock not being pushed down far enough. Or newer models could be spool lock on valve. Worst case bent or seized lift spool in valve or cylinders by passing internally.
Sep 23, 2011 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
Danfoss AVTB valve has stopped operating and is not passing water. Is there a method of manually opening the valve to allow water to flow until a repair is affected.
Hi, I am sure this is a n/c valve. The only way for this to happen is to remove the inner workings for water to flow. If there is no way to excess this valve, it would have to be removed, and the line reconnected with a hand full of fittings. I don't know if you are using copper, or galvanized pipe, but this is your best bet.
Shastalaker7
Feb 08, 2011 | Heating & Cooling
What tools do you need to take apart a PVG 32 Proprtional Valve off a Sauer Danfoss pump.
It depends on what your going to do withthe valve but here is a pratss site with break down of the pump if you want to see how it comes apart.
http://www.zemarc.com/?gclid=CMD_vcbchZ4CFQgtawodDQUUqQ
Nov 12, 2009 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
Danfoss TP5 programming manual required
This is the full manual:
http://danfoss-randall.co.uk/PCMPDF/6218.pdf
Very well hidden away on the Danfoss website!
Oct 29, 2009 | Honeywell Electronic Programmable...
Leaking Danfoss Tempress II.
The valve cartridge needed to be gently pried/wiggled free. It actually has two plastic pins that seat into the brass body. All fixed!
Oct 14, 2009 | Grohe Plumbing
Hydrolic arms wont lift up or down on Bobcat skidsteer 873
CHECK ALL THE SAFTEY SWITCHES ON THE SAFTEY BAR . IF THE UNIT MOVES FORWARD AND BACKWARDS THE SWITCHES AREN'T THE PROBLEM
Aug 23, 2009 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
Plumbing Logo
623 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
