Question about Kenmore 43389 Electric Double Oven
Top oven door will not unlock
The top oven door is locked and I can not get it to unlock. I was out of town for a week and when I came home it was like this. I cannot find my manual
  • tonyawells61 Jul 15, 2009
    I tried that, I turned the breaker off last night and turned it back on this morning and the lock light is still on and the door wont open
  • 441 Answers
Turn off the breaker to the oven for an hour and then back on that should do it
Posted on Jul 15, 2009
My oven door is locked after cleaning and it will not unlock
If the door will not unlock at the end of the clean cycle then you may have a problem the door lock/motor assembly. You should first remove the power to the oven for a few moments and then reconnect. This may reset the control and allow you to unlock the door. If you suspect that the door lock/motor assembly is at fault then you will need to unlock the door manually. The assembly is normally located between the main top and the oven and can only be accessed by raising the main top. This is very difficult to do because the screws that hold the top in place are inaccessible with the door closed. If the assembly cannot be accessed then you will have to form a wire hook,(coat hanger) and insert it between the door and the latch and manually pull the latch to the open position. Remove power to the oven before attempting this procedure and be careful not to damage the finish.
Dec 15, 2017 | Ovens
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
How can I open a stuck oven door after running the cleaning programme?
Did you release the lock on top of oven door? Oven would not start cleaning until this lock is in place.
Mar 23, 2016 | Ovens
Oven door won't close
if you look around under the handle or under the top of the stove on the front there should be thin lever. This lever is designed to lock the oven door closed tightly when you are activating the self cleaning oven feature. It is likely that someone accidentally lock the lever while the door to the oven was open. Simply find that locking lever return it to the unlocked position and your door should shut fine.
Dec 26, 2013 | Ovens
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
I have a frigidaire mef352bgwd electric oven- after a power outage the lock engaged (door open) and now blinks continually. Tried shutting off breaker for 30 minutes- no change.
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
Jan 07, 2010 | Frigidaire GLEB27S7A Electric Single Oven
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I CAN'T UNLOCK MY OVEN DOOR!
First get rid of the noise by turnining off te breaker.
You will have to pry the lock open.
This is common I use a small screwdriver and coathanger wire,then pull out oven enouhg to replace lock.
Mar 12, 2009 | Ovens
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Kenmore 43389 Electric Double Oven Logo
111 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
