Greetings
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure. Toyota
SOURCE: 1991 Toyota Camery Airbag light
try disconecting battery / if that does not work you will have to find out why it is staying on
SOURCE: airbag light is on
Air bag sensor got knocked loose and either needs to be replaced or needs to be re mounted. You may have to take it to a dealership to get them to figure out which one has gone
SOURCE: 2000 Toyota Platz malfunction indicator lamp stays on
let me tell you its solution....:)
do check all filters and engine oil...
if it still remains then replace its battery ...
its all done
SOURCE: airbag light goes on checked all fuses are not
SRS SYSTEM HAS A FAULT , THIS COULD MEAN MANY THING
INPORANT TO KNOW SRS DOES A SELF CHECK EVERYTIME YOU START YOU VEHICLE , THIS LETS YOU KNOW IF THE SYSTEM IS WORKING OR NOT.
IT LOOKS AS IF YOU HAVE A FAULT WITH A PART OF THE SRS CIRCUIT.
PLEASE DO NOT TRY TO FIX , COULD BE DANGEROUS!!!
YOU NEED TO TAKE IT TO YOUR LOCAL DEALER.
THEY WILL SCAN SYSTEM.
AFTERMARKET GARAGES DONT HAVE AXCESS TO THE SRS SYSTEM.
THERE COULD BE A SHORT OR OPEN IN CIRCUIT.
I HOPE THIS HELPS
The light for the Airbag/SRS system is on because the system control module has sensed a fault and turned off the airbag SRS system. What you must do now is have a scan done of the airbag module to see what fault codes show up in the airbag modules memory.
