Question about Lands Phones
VOIP will no ring
Just hooked up my VOIP phone and it will not ring. Ringer volume is up
  • jmccoy35 Nov 18, 2007
    I am using a VOIP phone at home connected through my cable modem. It is a NEC D-term IPK, model #ITH-8D-3(BK)TEL. Sorry for lack of info...I am new to this type of technology. Thanks so much for any help.
    They are working on it, but in the meantime, I am having to sit and literally watch for the phone to light up in order to know it is ringing. So, I thought I would post something on here to see if anyone knew of a function code to enter into the phone. I can see the call arrival button light up so I know I am getting the signal and when I get a call, I press call arrival and am connected to the caller. I am sure it is something simple. Thanks for all of your help :)
    New Friend:
  • 3 Answers
This completely depends on VoIP adapter, if u have good VoIP adapter it may consume depends on the voltage it may give the best ring, I'm suggesting you try this adapter Cisco ATA 186 Analog Adaptor
Posted on Nov 25, 2016
    New Friend:
    Problem Solver:
  • 12 Answers
That totally depends upon your phone volume,if your phone volume is by default low then you can not expect high volume from your voip.
Check the solution: Home best voip
Posted on Jan 11, 2015
This is related to the ringing voltage of your phone and the voltage provided from your VoIP adaptor. If your phone is a cordless one (e.g., most Motorola, GE models), try to unplug the power cord. It might get the ringtone back, but no more cordless handsets. While this problem does not have an easy solution, you might want to switch to a different phone or have another VoIP adaptor that supports high output ringing voltage.
Posted on Jul 30, 2009
    Novelist:
  • 201 Answers
Just "VOIP Phone" is not enough information to help you. There are many hundreds of different phones, connections, & setups you could have. What type of phone (make, model number)? Is this a VOIP phone connected through a home network, cable modem etc.. for home use? Is it a single line phone connected to a VOIP box connected to your cable modem? Is it a VOIP phone system connected to regular copper phone lines? Are you using a VOIP phone at home connected to a VOIP phone system at work?
Posted on Nov 18, 2007
  • Ben Jordan Nov 18, 2007
    That is a business telephone system VOIP phone made to connect to an office phone system. You are connecting this to a phone system at the office correct?
    Office phone system extension can be programmed to ring or not at the system level. It's possible your station port is not programmed to ring.
    Do you have anyone helping you with this? It can get extremely complicated!! Once set up properly you should be able to take that phone anywhere you can get a good high speed internet connection and use it just like you were at your desk at work.
  • Ben Jordan Nov 19, 2007
    Well, I don't know the specifics of your phone system but I do know the specifics of other phone systems. It sounds like your phone has permission to use those phone lines and to answer them but not to ring. This is the default setting in many systems where it assumes you have an operator answering calls and transferring to the right extension. In a busy office with many calls coming in it would be very annoying for your phone to be constantly ringing but most of the calls are not for you.
    It's unlikely this is a feature you can turn on yourself with a code at the phone because there are too many variables. Your system has many phone lines coming in... which one should ring? line 6, all of them, just 1-3-4&7? etc.. plus the system can be programmed with timers so your phone only rings after it has rung at another location 4 times with no answer OR in sequence so call 1 rings at Joe's desk, call 2 rings at Sue's, call 3 rings at Bob's and the next call rings at your's then start the loop over spreading out the call volume evenly. Then to top it off... all these rules can change in night mode. As you can see, it can get quite complicated.
I need to turn the ringer OFF on my AT&T 210/Lucent TrimLine.....sounds like a fire alarm...!!!
Search Results
FAQs - AT&T® Telephone Store
https://telephones.att.com/product-support/faqs/symptom/1591/89 Tip 1 of 8. If the phone does not ring at all, you may have the ringer turned off. The handset and base have independent ringer programming. To adjust the handset ringer volume: Step 1: Press MENU/SELECT on the handset when it is not in use. Step 2: Press ?DIR or ?CID to display Ringers, then press MENU/SELECT. Missing: lucent
[PDF]TRIMLINE® Memory Telephone 210 - Amazon S3
s3.amazonaws.com/szmanuals/62619bc8d4792f47b6654ed48c3548a3 AT&T and the globe symbol are registered trademarks of AT&T Corp. licensed to Advanced American .... Ringer Volume. The RINGER volume switch allows you to turn the telephone ringer OFF, or set it to ring at LO or HI volume. You can dial or answer calls normally when the ringer is off. Other telephones in your home will.
How to change the ringer tone on the AT&T Trimline 210 - YouTube
? 2:58
https://www.youtube.com/watch?v=xZxexCm7xtk
Apr 30, 2016 - Uploaded by kmbfanofpacman
I just figured out how that works after the day I got the phone and its pretty cool to be honest.Missing: my ‎lucent
[PDF]AT&T 210 User manual - Multi-Link Inc.
https://multi-link.net/wp-content/uploads/ATT-ATT210-Manual.pdf Make sure the ringer volume switch is not set to OFF. You may have inadvertently turned off the ringer. Press. ,. , , . If there are several other phones on the same ... 11. 12. For Customer Service Or Product. Information, Visit Our Website At www.telephones.att.com. User's manual. Part 2. TRIMLINE. Memory telephone 210. Missing: my ‎lucent
Lucent AT&T Trimline 210 Corded Phone Ring tone - Questions (with ...
www.fixya.com > ... > Lucent > Lucent AT&T Trimline 210 Corded Phone
Lucent AT&T Trimline 210 Corded Phone, ring tone related issues. ... If the ringer volume has been turned off, the handset will not ring ? ... ...ring tone im receieveing the voice ring tone but prefer the volume how can i change my ringtone When the phone is sitting in its normal mode hitting the "flash" button toggles through ...
Apr 07, 2018 | AT&T Lands Phones
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
Increase rings on fax machine
Above the start button, there is a UP arrow button which is for increase of ringer volume, just press repeatedly to increase the volume. The down arrow is for lower down the ringer volume.
Jan 07, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Oct 19, 2008 | Vtech Cordless 6041 Phone
Phone will not ring
I have the same problem for this hpone. The phone can answer and make call but not ring, of couse the answer machine function does not work. I used Rogers home phone and now the Linksys voip adaptor. But the phone works well with landline. I think the ring votage may not enough to ring the phone. Anyone get the solution?
Jack
Feb 09, 2008 | Lands Phones
GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
May 04, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
876 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
