Question about Hansgrohe 27118821 Brushed Nickel ShowerPower ShowerPower Single Handle Sho
I have lime deposits and hard water spots on my Hansgrohe showerhead, handle and sprayer. I would like to know how to clean it so as not to ruin the brushed satin nickel finish. Thanks!
  • 62 Answers
Use a product called CLR (calcium lime rust0 do not scrub.
Posted on Jul 16, 2009
How do you unscrew Hansgrohe showerhead (needs cleaning to remove calcium deposits)?
Easiest is to simply pour some CLR cleaner (from grocery or hardware store, it is a brand name) into a plastic bag, and tie the bag around the pipe with the shower head soaking in the solution.
Easy fix!
Jul 26, 2014 | Hansgrohe Home
Clubmaster shower not holding temperature. Hot water not coming through.
There's only there things that are clubmaster, a shower head, and two hand held sprayers.
They all spray water, they don't heat water.
Did someone install a new part, the one that's behind the wall ?
If they did, most have a safety so people don't get burnt and they need to be adjusted.
Apr 16, 2013 | Hansgrohe Clubmaster Showerhead, Steel
How do you remove the Metris S wideset faucet handle?
To remove the handle simply rotate the escutcheon counter clockwise and it will unthread from the fixation on top of the counter. Then the handle will lift off as one unit. You can clean them with CLR to clear up water deposits. If you need further instructions feel free to contact me Hansgrohe Tech 1-800-334-0455 press 2 for Technical and ask for David Scarborough. I'll be happy to help.
Apr 08, 2013 | Hansgrohe 31063821 Brushed Nickel Metris S...
Air rain shower head leaking
The most common issue with this type of head is water deposits building up in the spray face. This will cause the unit to express water from the venturi in the center of the spray face as well as other places. If this is the case the best solution is to remove the unit and soak it in CLR for about ten minutes. Then rinse it well and reconnect to the water source. Run water throught the shower head and while running rub the rubber water channels to further break up and clear out the deposits. Then repeat the process at least two more times or until the deposits are cleared out. If you need further help feel free to contact Hansgrohe Technical at 1-800-334-0455.
Jan 22, 2013 | Hansgrohe Raindance 240 AIR Showerhead ...
Spray doesn't work
Could be water deposits blocking the performance of the hand sprayer. Try cleaning it with CLR to remove deposits. If you need help finding parts or dealers feel free to contact Hansgrohe at 1-800-334-0455.
Jan 12, 2013 | Hansgrohe Plumbing
Stiff cold water handle bathroom Hansgrohe
If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Aug 07, 2012 | Hansgrohe - Lavatory Faucet - Centerset -...
How to un-fit Hansgrohe Chroma 3-ways handshower?
Hansgrohe hand showers have filtration sometimes on the inlet side of the hand shower. You must unscrew the smooth conical nut from the handshower to expose the filter and the flow restrictor. If your hand shower is not equipped with a filter gasket, you should use one to protect your hand shower from the particulate.
Filter gaskets can be used at your body sprays and shower head as well if you have them. If you have a Hansgrohe thermostatic valve you don't need the little filter screens, because the valve is filtering the water good enough. We do not recommend opening your handshower for cleaning. There would be a strong chance you may not get it together again, or it may become damaged.
If your concern is with a buildup of lime on the spray faces, you can use a decalcifying agent to dissolve the deposits, but do not soak for more than 10 minutes and then rinse well with clear water.
Best regards,
Phil Heslep
Hansgrohe Technical Support
North America
Jan 08, 2012 | Home
After about 3 months of use our Hansgrohe 10" Downpour Air stopped "raining" and began "streaming." Solid streams of water stream down.
do you by any chance have hard water? Calcium or lime buildup around around the spray holes will restrict the openings and result in higher pressure/lower volume streams. A good soaking in CLR should clear up this problem.
May 08, 2011 | Hansgrohe Downpour AIR Showerhead - 10",...
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
Low water pressure/slow flow Blanco Elan faucet 2.2 gpm
pull the sprayer out, get some plyers or a wrench and losen up the connection. between the hose and the sprayer there is usually a screen take it out and walla it should take care of you, it also helps to leave the sprayer in some lime away or vinegar for a few hrs to get the hard water losened up in it
Jun 27, 2009 | Blanco ELAN II 1 Handle Pull-out Spray...
Hansgrohe 27118821 Brushed Nickel ShowerPower ShowerPower Single Handle Sho Logo
485 people viewed this question
Top Hansgrohe Home Experts
Shehu Pro
Shehu Pro
 John
John
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
