Washing Machines Logo
B
Bob buchanan Posted on Jan 29, 2016
F-08 indicated. - Hotpoint Washing Machines
Charles Christie
Level 1:
Habit-Forming:
New Friend:
  • Contributor 16 Answers
  • Posted on Feb 04, 2016
Charles Christie
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
16
Questions
Helped
8374
Points
17
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
How to remove e-studio 2508a time for maintenance
The conditions of the PM display consist of the codes of the setting mode (08) for "the setting value
treated as a threshold of the PM display", "the counter indicating the current number of prints and
driving time" and "the setting value which determines the display conditions".
08-6190: Setting value of PM counter [process unit (K)]
08-6191 : Setting value of PM time counter [process unit (K)]
08-5554 : Setting value of PM counter [developer material (K)]
08-5555 : Setting value of PM time counter [developer material (K)]
08-5562 : Setting value of PM counter [parts other than the PM parts of the process unit]
08-5563 : Setting value of PM time counter [parts other than the PM parts of the process unit]
2helpful
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Install auxiliary running light and directional indicator mirrors
Jim as a mech at the HD place he cant modify it,but you can.Bench test the part then meter the circuit on the bike you will have it in no time.
3helpful
Studio 450 me presenta error f120
F120 indicates Database abnormality.
What u can do:
Rebuild the databases. (Perform 08-684.)
If the error is not recovered, initialize the HDD. (Enter "2" at 08-690.)
Error code f-08
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Hope this helps.
10helpful
F-08 Error message keeps appearing
Error code F08 indicates that the heater relay cannot be activated.
Check connections on
1--pressure switch.
2--heater element.
3--control module.
If you still cannot get it to work, then you are probably going to have to call an engineer.
Please rate my solution.
Thanks.
5helpful
F-08 is on the display
Error code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check module connections.
  4. Check and clean pump and or pump filter.
Thanks.
1helpful
Error Code 08:11 HP z6100
The 08 portion of the code indicates FRONT PANEL. the :11 is an action code requesting RESEAT, CLEAN meaning you should reseat the connectors at the display and on the other end at the electronics. Cover removal is explained in the service manual which can be downloaded here: www.lpscomputer.com/ec/manuals.htm
Error code 08 comes. Tape ejects automatically. Auto off stays on. Can someone help
error 08 indicates "video drum not spinning." could be as simple as a bad tape, but most likely is defective video drum assembly or defective motor driver circuit.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
